breslin header bolts
Re: breslin header bolts
http://www.go-breslin.com/
call up and tell them the year of your car and they will offer you the 3/4" and the 1", make sure to get the 1" bolts! They rock, i just put them on.
My header bolts never backed out, and I have the standard ones that came with my MAC's. I don't believe much in the locking bolts. If you retorque the standard bolts every day for a week or so, you'll be o.k. I also used the Mr. Gasket Ultra seal gaskets, which are very similar to the Felpro's. I did have problems with the copper gaskets however, they had very small leaks.
Dan
Dan
If ya don't get the stainless,take out the locking screw on all of them and put a small dab of anti-seize on them to insure they will unlock when ya want to take them out or re tighten.
locking screws as well. It sure can't hurt anything.
Originally Posted by onetransam4u2nv
why not buy the lockers and set and forget about it. i don't wanna tighten them up every week or so. this car takes up enough of my time.(dam hobbies)
And some of those copper gaskets are shaped wrong for the headers in that the header openings might cross over the boss in the lower portion of the gasket and have a built-in leak on all 8.
94Z28LS1toLT1
Apr 7, 2015 05:37 AM
SavageZ28
17
Jul 14, 2002 11:04 PM
