burnt coolant smell thru a/c after flush
Old Jul 3, 2003 | 02:07 AM
scoobysnax83's Avatar
Well I just flushed the system today and put some dex cool back in. Everything went fine, temps good, bled system. But I've noticed at about the 1/2 mark on the gauge, I start to smell burnt coolant through the A/C system when its in vent mode. Does coolant have an effect on hot surfaces like oil does and continue to smell for awhile? Its weird. I would think that it would be burnt off by now, but I still smell it. Any ideas? Or anything I should worry about?
Old Jul 4, 2003 | 12:13 AM
fbird95's Avatar
Just how much did you flush it out?
I am always warning people about over flushing, the system. No the gunk in there causes cooling restrictions, but it also clogs up little leaks in the system. Its possible that you have a leak somewhere and the a/c vents are picking up the air from it. Maybe a steam leak.
Old Jul 4, 2003 | 04:27 AM
thanks fbird, I appreciate the feedback, but the smell has gone away. It was only coming in when in vent or A/C mode, when I had it recirculating it wasn't there. It must have just needed to be burnt off from spilling it inside the engine compartment. But again, Thanks
Old Jul 4, 2003 | 02:40 PM
fbird95's Avatar
Well thats good. At least it wasnt a major problem. sometimes the spilled whatever, just has to get burnt up.
Old Jul 4, 2003 | 04:01 PM
I actually narrowed it down a little more. The reservoir was overfilled so when it was getting hot it was pushing the water out and thats probably where the smell was coming from.
Old Jul 6, 2003 | 04:34 PM
fbird95's Avatar
I have mine over the full hot level when its cold. I have done this on all GM cars i have ever had, so hopefully i wont have the same issue as you.
Pwilson59
Sep 3, 2015 08:47 PM
ZXXVIII
Sep 1, 2015 10:13 PM
WPHIG2
Aug 27, 2015 06:37 AM
MikeWhitener
Aug 2, 2015 06:17 PM
Noct
Jul 14, 2015 01:18 AM
