Breaking up at High RPMs
Old Jun 28, 2005 | 07:18 PM
Heatmaker's Avatar
Advanced Member
After the Long tube install... the car feels to be breaking up at High rpms's it's really bad in 1st gear... you can feel it in all the gears really... as soon as you stomp on it... the needle will go smooth to about 4.5K then the car will start breaking up and make a choppy kind of sound. Then at about 5K or so the car will get smooth again. It feels worse if you downshift into forth nad stop the pedal. It breaks up around 4K and gets choppy until 5K and then it's smooth again. What might be going on?
I should also say this only happens when you really push the pedal down.
Whe nyou eaaase into the rpms it doesn't break up. Just when you push it down hard as if your racing. Which is still very bad.
Old Jun 28, 2005 | 08:02 PM
1quickgt's Avatar
Re: Breaking up at High RPMs
had the same problem wiht my cut out check opti or plugs
Old Jun 28, 2005 | 08:15 PM
besz28's Avatar
coil or i bet wires especially after long tube install.do yourself a favor get some otvc wires. look nice and keep wires away from headers.good luck
Old Jun 28, 2005 | 11:41 PM
OBE1 95Z28's Avatar
Another vote for checking the wires. Look for arcing around the plugs with the motor running in the dark. Any chance you have an exhaust leak at the manifold (loud tapping noise)?
Old Jun 29, 2005 | 12:41 AM
Heatmaker's Avatar
Advanced Member
No manifolds leaks, but I did think I saw a halo around one of the plugs.
Old Jun 29, 2005 | 01:25 AM
slowpoke96z28's Avatar
plug wire time. use boots or go with thick insulation. and remember, the spark is looking for the easiest path to ground, and if that means going through the opti due to a bad plug or wire, it will.
Old Jun 29, 2005 | 08:05 AM
Maldo's Avatar
If you need some OTVC wires check us out! We are the only company out there that makes wires that bolt right in....
Old Jun 29, 2005 | 09:01 AM
Heatmaker's Avatar
Advanced Member
THat's very wierd... I was just about to place an order with you guys, but I was wondering... what exactly is your heat shielded wire option?
Old Jun 29, 2005 | 11:13 AM
MPZ28's Avatar
More often then not, the opti is the root of all evil in LT1's. With headers also though, ive gone through my fair share of plug wires.
Old Jun 29, 2005 | 11:46 AM
Maldo's Avatar
This is a protective sleeve that is added in the building process of the ignition wire which extends all the way down into the boot .... This is not something we simply slip on after the wire is made.
Please check out our web site click here
or check this out for a close up shot and you can see the quality we build into our custom wire sets.
THX Jim
Victor Lamb
Aug 26, 2017 02:52 PM
blac94Z
19
May 13, 2015 04:50 PM
lt1matt
Mar 21, 2015 07:35 PM
1996LT1Z28
Mar 8, 2015 08:16 PM
Penthos
Sep 6, 2002 09:34 PM
