Breaking in a new motor
Old Oct 18, 2003 | 07:20 PM
acslinger2525's Avatar
I just built a lt1, .030 over and all, the cam is already been broken in another engine. The computer is already been tuned by www.madz28.com. Do i need to put some miles on this motor before i just give it hell? Its got a new transmission with a new stall, if that makes a difference.
I appreciate the help
steven
Old Oct 18, 2003 | 07:25 PM
TreySpeed's Avatar
On permanent vacation
give it hell in 50 miles
Old Oct 18, 2003 | 10:36 PM
95 Silver TA's Avatar
When I broke in My new 383 here is what I did.
Let car run for 20 minutes on first start up and chaned oil and filter. Took it easy for another 500 Miles and changed the oil and filter again.....Then I started havin some real fun with it
I used 10W30 Dyno Oil on my break in.
Hope that helps,
Claude
Old Oct 18, 2003 | 11:29 PM
Thank you for your info
steven
Old Oct 18, 2003 | 11:31 PM
Transamdriver's Avatar
Hope that helps,
Claude
Yep when you first crank it keep the rpms above 1500 and below 3000 for the first 20-30mins and then change the oil and filter. Then in 500 miles change the oil and filter again..
Be sure to keep the revs under 3500 at the most and try not to "lug" the engine on the hwy for the first 500.
Victor Lamb
Aug 26, 2017 02:52 PM
armedtrigger
Feb 24, 2015 08:30 PM
cmyname1
Feb 19, 2015 08:38 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
