Brakes suck. The camshaft is robbing my vacuum.
Old Aug 9, 2010 | 04:52 PM
wrd1972's Avatar
Been chasing a hard braking condition under panic stop conditions. All braking components have been determined to be good including the master and booster. I have to stand on it to make the ABS kick in under panic stop. FTR I have 12" LS1 brakes too.
For giggles I put a vacuum guage on the intake and I have:
12" at idle with AC off
10" at idle with AC on
Stock cam made 20"-22" IIRC.
I am confident I dont have any vaccum leaks. Motor runs well and BLMs are near perfect. So its the cam robbing my vaccum that is affecting my braking. I have a 224/230 which aint that big. But its on a 107 LSA with lots of overlap and according to folks who are smarter than I am, thats what is doing it.
What are my options here other than replace the cam with a tamer LSA??
Old Aug 9, 2010 | 07:20 PM
rclearyiii's Avatar
Just fixed my friends brakes with low vacuum by putting in a vacuum cannister between the booster and vacuum supply line. Much better than it was before.
Old Aug 9, 2010 | 10:45 PM
Cam's not "big", but the 107 LSA increases overlap and reduces engine vacuum at low RPM.
Old Aug 9, 2010 | 10:48 PM
camarobird92's Avatar
Try a vacuum canister. I have to run one on my car to get any kind of power brakes.
Old Aug 10, 2010 | 10:41 AM
wrd1972's Avatar
I did and I saw little to no improvement so I pulled it and sold it.
Old Aug 10, 2010 | 11:46 AM
WS6T3RROR's Avatar
Here is my fix for crappy vacuum/brakes.
http://www.cvrproducts.com/vacuum_pump.html
Give a pep talk to your wallet it's gonna sting.
Old Aug 10, 2010 | 11:53 AM
wrd1972's Avatar
$400.00 for something that sucks should be against the law .
What is your vaccum without the pump?
Old Aug 10, 2010 | 11:26 PM
IceMatrix69's Avatar
It's the divorce that really hurts
Old Aug 11, 2010 | 01:17 AM
MikeGyver's Avatar
Just go to the yunkyard and get a brake booster vac pump from a '04 silverado for $30.
Old Aug 11, 2010 | 06:22 AM
wrd1972's Avatar
Is this what you are referring to?
http://cgi.ebay.com/ebaymotors/03-04...Q5fAccessories
Is that a pump coupled to a resovoir?
RX Speed Works
Jul 24, 2015 02:25 PM
Boss002
Jul 24, 2015 10:47 AM
whitehooptie
Jul 12, 2015 06:10 PM
mrwz28
Jul 8, 2015 09:11 PM
