Brake Problem
on my 94 Z i have been having the brake light go on and off. When the pedal reaches a certain point the light will come on and stays on as you release off the brake. meanwhile, if you hit the brakes to the same point again the light will go off... but there are times when you can hit the brake once and the light comes on and goes right off.
So i replaced the master cylinder and bleeded the system.
and still this damn light will come on.
Fluids are fine and the brake lines dont leak...
Any other suggestions??
Brakes work but not up to their potential like a stock car.
i will try to bleed the system again maybe there is a little bit of air but im not sure
Magenta_Hearts
Mar 25, 2015 10:24 AM
dluna333
15
Mar 13, 2015 12:30 PM
