Braided Steel Brake Hoses
Old Sep 23, 2004 | 09:27 PM
SantaCruz163's Avatar
I just finished cleaning, prepping, painting all the parts for my LS1 brake conversion and it is ready to go on the car. The only part I am concerned about is the brake hoses. When I bought the conversion it did not come with the LS1 hoses so I was just planning on using the LT1 hoses and bending the bracket. I was alittle iffy about that though, I don't want to half *** something as important as brakes. So I want to go with braided sttel hoses. I've been looking around but haven't found anything really, will brake lines from a 84-92 Vette fit? I know Thunder Racing sells them, but is there any place where I can buy just the fronts? Need some advice
Edit: I found this and was wondering if any applications would fit other than the Camaro ones? Mind you, I would like to just buy the front 2
Old Sep 25, 2004 | 11:06 AM
Bud M's Avatar
Re: Braided Steel Brake Hoses
You can just order a set of Earl's lines for a 98 and later f body. The rears will fit LT1 brakes although the drivers side hose is a bit long.
Old Sep 25, 2004 | 02:04 PM
dkeers's Avatar
If you have an Earls near you, they will custom make any line you need.
Old Sep 25, 2004 | 04:15 PM
Heatmaker's Avatar
Advanced Member
Ha... I remember one time I dropped my Caliper... and POP! went my line... what a sorry mistaqke that was... had to buy a whole $100.00 kit to replace one line...
Magenta_Hearts
Mar 29, 2017 08:54 PM
R@mpage
Apr 20, 2015 10:02 AM
Jlo
Apr 3, 2015 10:32 AM
dale3in98
Feb 14, 2015 12:18 PM
