Bought SS Hood, now where do I get the SS intake kit?
Old May 30, 2005 | 09:11 PM
AdamZ1LE28's Avatar
My 96 Z is in the body shop right now getting the SS hood put on it. I bought the Suncoast Creations SS style hood at a local place, and I want the SS intake because it should increase my horsepower. Anyone know where I can get it? Thanks.
Old May 30, 2005 | 09:16 PM
Madd Z28's Avatar
Re: Bought SS Hood, now where do I get the SS intake kit?
You can get the SS air induction kits from several places, FBODYMOTORSPORTS.com has them for about $200 some. Infact, they sell the hood and airbox assembly as a kit for people who want to buy the whole setup.. which runs about $750.
=== CORRECTION ===
The box is $305. http://www.fbodymotorsports.com/inc/pdetail?v=1&pid=143
Old May 30, 2005 | 09:18 PM
96vortechSS's Avatar
Just put a moroso cai on from summit. You'll get the same hp. But if you must have a look a like 96/97 ss intake assy go to www.fbodymotorsports.com
Old May 30, 2005 | 09:34 PM
AdamZ1LE28's Avatar
I have the K&N FIPK kit right now, do you think I'll gain any power by putting the SS intake on it since I'm getting the hood?
Old May 30, 2005 | 09:41 PM
AF96Z28's Avatar
i have the same setup. I just wanted the ram air, and a place to mount my msd. I actually bought my airbox w/ k&n filter from another member for 100 bucks. Do a search, and you could save some real $$
Old May 30, 2005 | 09:54 PM
stereomandan's Avatar
No you will not gain from the SS intake, over the FIPK.
I have the K&N FIPK with the SS hood. I use the ram air for engine cooling rather than using it for the intake.
Dan
Old May 30, 2005 | 09:58 PM
DavesLT1's Avatar
Dan
this is why I am buying a SS hood, the ram air doesn't have much more HP than a CAI, and this is when you're at really high speeds.
Old May 31, 2005 | 06:03 PM
AdamZ1LE28's Avatar
So you guys don't even think its worth it to get it?
Old May 31, 2005 | 06:17 PM
mattybz28's Avatar
No.
Save your money.
Old May 31, 2005 | 06:34 PM
AdamZ1LE28's Avatar
Old May 31, 2005 | 06:51 PM
Quickshotkimber's Avatar
The ss air scoop is one of the worst ones made. The air is actually more likely to blow over the scoop instead of into it due to the position. The hood also acts as a giant heat soak because the air has to travel so far to reach the air box.
Old May 31, 2005 | 07:22 PM
spcearle's Avatar
if ya still wanted one i'd send ya mine and possible some money since it isnt perfect for a real cai system since mine just has one of the cheap ebay rice ones in it that i dont like
Old May 31, 2005 | 08:50 PM
Doug 97SS's Avatar
Guess I will chime in since I own a 97 SS. I can tell you from first hand experience I ran 2 tenths quicker swapping to a K&N FIPK then I did with the stock Ram Air Setup. Don't get me wrong, the Ram Air works, I think the formula worked out to be .3 lbs of boost. So it is worth something. Too bad you gotta be going almost 200mph to get that.
The Ram AIr setup looks cool. I will give you that, but the Lingenfelter, Moroso, K&N, AS&M, or SLP CAI are better then the stock setup.
Note: THere ARE some people out there that have had great success with their Ram Air setup, but I wasn't one of them. I think of everyone I asked (thats 96 or 97 owners) everyone of them but 1 said they were quicker with a CAI then the Ram Air setup.
I am sure if you do a search you will find what I said to be true.
Also, if you decide to go to Ram Air, you are going to need to watch the Air Tube Fitting on the drivers side manifold. On a 96/97SS this pipe is shaped like a "U" where as a stock LT1 car its shaped like a "7" because of the Ram Air duct work.
95chwagon
Feb 28, 2015 12:02 PM
CARiD
Jan 27, 2015 06:27 AM
CARiD
Jan 14, 2015 04:00 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
