bottom end and internals, durability for 600HP
Old Aug 2, 2008 | 02:11 AM
bkpliskin's Avatar
hey guys, so here's what's going on....
I'm going to be doing a H/C package....more than likely a mild cam...taking the heads to a local machine shop for a "stage II" port and polish, 3 angle valve job and such, the usual head work. I figure this, with my current mods, will easily put me over 400 crank hp
well here's my question....after that is completed, I fully intend on supercharging, which of course will involve a fuel system upgrade as well,
this should throw me over the 600 crank hp mark
will my 2 bolt main hold up? is it even going to be possible to put that kind of power down without destroying parts of the engine or am I going to need new pistons, rods, etc?
I understand there will typical breakage issues with the tranny and rear which could occur at any time
Old Aug 2, 2008 | 07:07 AM
rskrause's Avatar
Moderator
Maybe, but I wouldn't try it.
pistons - yes, definitely
rods - debatable
crank- debatable
Correct
Rich
Old Aug 2, 2008 | 09:52 AM
ulakovic22's Avatar
Rich must be in a good mood today
I don't know your exact plans but I would do a H/C setup on the stock shortblock while saving for a forged bottom end. Most of your stock components will be crap if you plan on making 600 fwhp. Also will your mild cam be designed for boost or are you going to buy another cam when you finally go forced induction?
Old Aug 2, 2008 | 10:07 AM
96capricemgr's Avatar
If it detonates it will crack the pistons and if it doesn't detonate the pistons/rings may get hot enough to butt the ring gap and rip to top off the piston.
Understand that 400 crank HP is NOT a lot and that to have 600hp at the crank with a blower the engine is actually being loaded with say 650hp(guess for illustration purposes) because it is also making the power to drive the blower.
Seems like an irresponsibly aggressive goal for a near stock compression boosted engine.
Old Aug 2, 2008 | 10:29 AM
bkpliskin's Avatar
how much for a forged bottom end???
Old Aug 2, 2008 | 10:48 AM
383racecar's Avatar
rods - debatable
crank- debatable
Correct
Rich
i been on a 2bolt block for 2year going 10.6-10.1s at 130-136 with no problems. car weights 3700 with me in it so i know it makes well over 600h.p at the crank to pull these times. i have egale 4340 crank and h beam rods with srp forged pistons.
Old Aug 3, 2008 | 07:34 PM
ulakovic22's Avatar
Figure $800 for machining, that includes bore, align hone, decking, assembly, etc., so just tack on parts to that. New will be $1800 I would guess off the top of my head. Used would be considerably cheaper depending on the deals you find, so all in for a forged SB would be $2500-$2600.
Old Aug 3, 2008 | 10:11 PM
slomarao's Avatar
So long as your 600hp is crank thats not too bad. If you planing on a 350/355 i would re use the stock crank, lots of guys have taken it to 750hp and beyond that. You could re use the stock rods too but by the time you pay for arp bolts your better off going with cheap forged ones. Pistons, no way. They are not going to hold up.
Get a quality piston (there are many) and have the rings gapped for the blower. Depending on rpm's i would stud the mains or go 4 bolt. If your going to stroke it stay with a cast crank at 600hp. 650,700 hp i would go forged. Your starting to wake on thin ice after 600.
Assembly and machine work can go a long way. Pick a known engine builder or take your time doing it yourself. Those two can either make you or break you, so make it a sure thing.
Unless your local shop is Advanced Induction I would really send your heads off to AI or Llyod Elliot. It will be worth your time and hassle. Every motors potential is in the heads, do them right. Another thing to consider, for roughly $800 you can get heads with full hardware flowing 250/185. I bet you would be over 1k for somewhere local to achieve those numbers.
Good luck.
Victor Lamb
Aug 26, 2017 02:52 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Apr 16, 2015 09:57 AM
Killer94z
Jan 13, 2015 12:06 PM
RichJ
Sep 26, 2002 09:43 AM
