Borla XR-1 or Dynomax bullets
Old Aug 19, 2003 | 09:59 PM
ponyackn's Avatar
Is there that much of a difference in quality sound wise for their respective prices?
What I want to do is keep my Loudmouth catback, remove the resonator like others seem to be doing, and put JetHot lts with a custom, dual cat y pipe.
Should I go with the XR1 or save some money by buying a 16'' dynomax?
Old Aug 19, 2003 | 10:08 PM
The Borla XR-1 is an excellent "high flow" muffler, but doesn't provide a whole lot in the way of noise reduction. I run a 3" x 12" on each collector, and they sounded like wide open headers. Got a little quieter when I added 3" pipes back to the axle. Don't know how they compare to a Dynomax.
Old Aug 19, 2003 | 11:17 PM
Canadian z28's Avatar
I didn't know you could just buy the Borla muffler, i thought you had to buy the whole cat-back, or the mufflers and tips section.
If you can just buy the muffler how much is it, and the part number if you don't mind me asking
Old Aug 19, 2003 | 11:42 PM
ponyackn's Avatar
Thanks Injuneer, I'm particularly lookin for something that will tame the Loudmouth's rasp and loudness when driving normally. It's loud enough with shorties+cats+LM, even though WOT sounds perfect. But then again, you're using a 12" and not the 16". Maybe that makes a noise level difference
Canadian z28, looking at my summit mag, the Borla xr1 comes in several different inlet and outlet sizes with prices ranging from $149 to $269. I dunno which would be the appropriate size in our case.
The dynomax bullets are around $30. Huge difference. Hopefully more will chime in their opinions on both. I simply need the best sounding bullet or muffler to replace my resonator
Daniel
Old Aug 20, 2003 | 11:16 AM
Daniel
If you go with the borla and find the part number let me know.
Thanks, Patrick
Old Dec 5, 2003 | 11:28 AM
ThotYouKnew's Avatar
sorry to drag this post out from the ice age but what did you end up going with? if you went with the borla i think it would've come with a 1,000,000 mile warranty...ha if it looks like it is gettin old just hack it off and have another sent to you ha
Old Dec 5, 2003 | 11:37 AM
People seem to be confusing the Borla "rear" mufflers for the 4th Gen with their XR-1 series "race" mufflers. You can buy a Borla 4th Gen specific cat-back, and get the single-in/single-out muffler that hangs behind the rear axle. Or you can buy a Borla "rear section" muffler only. That is a typical single-in/dual-out cross-flow muffler, 4th Gen specific, not the same one that comes with the catback. And based on my personal experience it is a very restrictive 2.5" muffler.... not something you would put on anything other than the stock engine. Sounds very good though.
The XR-1's are single-in/single-out, straight through mufflers in your choice of diameter and length. They are generic, not 4th Gen specific. You pick the size you want, and they are available in the JEG's or Summit catalog. I use them as "collector" mufflers, and only added outlet extensions after my local track required all exhausts to end behind the rear edge of the door.
3 x 12 XR-1 collector muffler
Quickss96
Jan 29, 2016 05:56 PM
WobblySausage
Oct 7, 2015 02:44 PM
Slayer
Aug 17, 2015 03:55 PM
KYWes
Aug 10, 2015 07:03 PM
colts0455
Jul 28, 2015 11:28 PM
