Borla Flow Control Plates, Few quick questions...
Old Aug 6, 2003 | 05:10 PM
Hyperspeed97z28's Avatar
Question Borla Flow Control Plates, Few quick questions...
Will these work on a non-borla cutout ???
Old Aug 6, 2003 | 06:21 PM
KrazyKamaro's Avatar
The borla plate should work providing that your cutout is the same size as the plates. The only problem that I forsee is that since the plate is not sandwiched between two steel flanges like in the borla setup, it may bend or warp. Not that this is a big problem it on a cutout. But If I were you i'd just get a chunk of sheet metal and drill or puch a hole in it to the desired size, then cut it down to fit on your cutout, drill your holes to bolt it up. Then just put it on. BTW let me know if this works out for you i'll write it down somewhere and keep it in my bag of exhaust tricks.
Old Aug 6, 2003 | 07:43 PM
Well I already have the 4 borla plates... might as well use them =0p
Old Aug 6, 2003 | 08:03 PM
QCKZ28's Avatar
it will probably sound like a bad exhaust leak under your car
DirtyDaveW
Mar 15, 2015 07:01 PM
Jan 23, 2015 01:13 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
JTP
Jul 20, 2002 08:24 PM
