Bored to 52mm stock tb, uses same blades?
Old Jun 13, 2007 | 11:15 PM
Z28LT1_Just_Nasty's Avatar
I've seen the stock bored out TB's on ebay, they go for half the price of an aftermarket one. Just curious do they use the same TB blades? If they do I know I'm somewhat decent with a dremel and could easily pull off the same thing. Of course I'd want to do it on a spare tb just in case. If its more trouble than its worth then I really don't care either at my power levels I probably won't see any gains anyway. Just looking for a new project to get into because I'm bored
Old Jun 13, 2007 | 11:22 PM
speed_demon24's Avatar
How would they use the same blades when you increase the bore size from 48mm to 52mm.
Old Jun 14, 2007 | 04:52 AM
Joe B's Avatar
And you would NEVER want to completely enlarge a throttle body(from 48mm to 52mm or 58mm) with a dremel or any hand held grinding or porting tool ......the TB bores need to be nice and consistant all the way through (IE:CNC)...........the unts from ebay(from Jblum), in addition to being precisionly CNC bored, have been redrilled for shaft bearings(instead of the factory bushings), and new better sealing(larger ha ha) throttle blades.....you can also send your TB in to him to have the work done on your exact unit, which is what I did...........Joe
Old Jun 14, 2007 | 08:52 AM
Oh well was just looking for something to keep me busy, I have off for a few days so no harm no foul. Time can't pass fast enough for my cut out and LCA's to show up on my door. Thanks for the information though.
Old Jun 14, 2007 | 09:13 AM
shock6906's Avatar
You're going to need more than a throttle body to keep you busy for a couple days. I had mine swapped in around an hour and a half or so. Sounds like you need to do a header install.
Old Jun 14, 2007 | 11:22 AM
Haha I will never do another set of headers ever again, once was good enough for me. That was such a pain in the butt. It's pretty cloudy out today, I think it's going to rain otherwise I'd paint my calipers to keep me busy. Anyone know of any other little projects I could keep myself busy with?
Old Jun 14, 2007 | 11:26 AM
oneclean97z's Avatar
haha change the plugs and wires lol
Old Jun 14, 2007 | 11:39 AM
MARKTHOMASBRAND's Avatar
Obviously not LT1 related,but you could remove your side mouldings .
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
canbaufo
May 25, 2015 12:01 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
