boosted lt1 paxton
Old Jan 16, 2009 | 10:19 PM
paxtonLT1's Avatar
boosted lt1 paxton
hello i have a 95 TA with a paxton sc and stock lt1 bottom end from GM with 7,000 miles on it. the heads are rebuilt with little port work. but any way the car has now got massive blow by its shooting the dip stick out and spraying oil out of the back of the intake manifold. the pcv is hooked up to the unboosted side of the sc so im thinking the rings blew.... what do you think i should do can i just slap some forged pistons is it and call it a day? if so what wold you use? its only pushing 6 lbs of boost and i dont see the point on over building it just wamt somthing cheap that i can count on thanks
Old Jan 17, 2009 | 09:17 AM
First, someone has to verify the cause of the blowby.
I think you might get better results on the "Forced Induction" forum.
Old Jan 17, 2009 | 09:29 AM
87bandit's Avatar
stock pistons shouldn't have a problem with 6psi
sounds like its something else
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
