Bolts for Hooker Long tubes...
Old May 10, 2006 | 08:23 PM
94EvilZ28's Avatar
Alright...well my engine is done...and should be shipping and need to get the final little things bought. What bolts are you guys using on your Jet Hot Hooker Long tubes? I had some ARP's but they mate right against the header manifold...do the make some spacers that will help move the head back a bit?
James
Old May 11, 2006 | 09:07 PM
94EvilZ28's Avatar
Re: Bolts for Hooker Long tubes...
Nobody else in here is using Hookers? Or havent even heard what Im talking about?
Old May 11, 2006 | 09:22 PM
Dave89IROC's Avatar
no idea what you are talking about
Old May 11, 2006 | 11:01 PM
matLT1's Avatar
I just used the bolts that came with the headers. Haven't had any problems or leaks.
Old May 11, 2006 | 11:02 PM
hsyr's Avatar
I'm pretty sure he is talking about header bolts
Old May 12, 2006 | 12:51 AM
Demus's Avatar
I'm using stage 8 locking header bolts. I don't see why you'd want a spacer in there? I think it would actually make it harder to get at some of the bolts.
Old May 12, 2006 | 06:34 AM
94EvilZ28's Avatar
Yes I am talking about the header bolts...They are a pain in the *** to get at now and if the heads were sticking out a bit more it would be easier to get too I would think...And yes...the do make spacers for it and they work just fine...just seeing if any guys using these same headers use them?
Old May 12, 2006 | 02:35 PM
sssalah's Avatar
The spacers are actually to convert from the small block style bolt pattern with six bolts per side to the 7 bolts per side. You dont need them. I'm using the 3/4" ARP stainless hex bolts without any issues.
Old May 12, 2006 | 06:52 PM
RunRiot's Avatar
I use the 3/8" x .750" ARP 12-point bolts, and an old 3/8" box wrench that I ground down around the outside. It's fairly thin and looks fragile but it works. I also bent it 90 degrees to give me more reach-around.
It also helps to start all the bolts 1 or 2 threads and tighten them down gradually. If the flange is up against the head there's no way to get a couple of them in.
Jan 5, 2015 07:14 PM
ModdedNerd
Jan 1, 2015 10:56 AM
RedLineRev
Jan 23, 2003 03:51 PM
Wicked
Jul 29, 2002 04:17 PM
Wicked
Jul 25, 2002 04:19 PM
