Boaring out maf
Old Apr 15, 2005 | 11:28 AM
  #16
97bowtie's Avatar
Re: Boaring out maf
As already stated, don't mess w/it. There is much more to porting the maf than simply "getting more air flow". Anytime you mess w/the MAF, you will need to recalibrate the MAF via LT1 Edit/Tunercat, etc. The PCM is calibrated to work with the stock MAF and anytime you change how air flows across the MAF, you need to recalibrate the MAF tables in the PCM.
  #17
slimdawson's Avatar
Re: Boaring out maf
Yeah, don't mess with it. You wouldn't trick your scales to make you "think" you weighed less would you? Exactly, you want an accurate measurement.
Old Apr 15, 2005 | 01:37 PM
  #18
trans9_5am's Avatar
Re: Boaring out maf
If you know how to program the PCM and have alot of time to do so...then go ahead and port it. If not you should not port it but removing the screen has proven to flow alot more air.
Brandon
Old Apr 16, 2005 | 11:42 AM
  #19
slimdawson's Avatar
Re: Boaring out maf
Even if you do have tuning capabilities, still don't touch it. Unless you have a way of flowing the maf and compensating accordingly.
Old Apr 17, 2005 | 08:18 AM
  #20
BlueCamaroZ28's Avatar
Re: Boaring out maf
I agree.
Check this link.
http://www.1967camaro.net/Engine_Mod...f_porting.html
Old Apr 17, 2005 | 01:06 PM
  #21
MarineReconZ28's Avatar
Re: Boaring out maf
If you do pull the screen, make sure you don't misplace the c-clip. I would love to put mine back in except I lost the clip. I think that might be the cause of my car running a little rich.
Double aught
Oct 2, 2015 11:29 PM
marlar98
Sep 19, 2015 07:53 AM
tommalcolm
Sep 11, 2015 03:39 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
damnyankee36
Sep 9, 2015 07:06 PM
