BMR or PA K-member ?
Old Oct 26, 2003 | 04:38 PM
trax's Avatar
Question BMR or PA K-member ?
I'm not sure which one I want. Based on what I've read on LS1Tech, chrome moly doesn't like to flex which makes it a bad choice for street driving.
Any personal experience / recommendations?
Old Oct 26, 2003 | 07:04 PM
BES-383's Avatar
Have had the P-A for 2 years now . No problems on the street or at the track.
Old Oct 27, 2003 | 08:36 AM
IDOXLR8's Avatar
You may want to do a search to find more info.
Old Oct 27, 2003 | 09:29 AM
mongse_1's Avatar
I have heard the same thing w/ chromoly(welds may crack with street driving). I went with mild steel on mine, partly because of that. The difference isn't that much weight-wise. If you inspect the welds often, you shouldn't have a problem w/ the chromoly stuff.
Old Oct 27, 2003 | 10:39 AM
simple's Avatar
you have another choice also...www.AJEracing.com
i've been running the BMR k-member and lower A-arms for about 2500miles on the street and have no complaints, altho i need an alignment, my fault not the k-members, like said b4 do a search under chromoly there was a very good discussion on it in the advanced tech section not that long ago, i'm sure it will answer alot if not all of your questions or make you ask more
Old Oct 27, 2003 | 10:42 AM
I know there has been at least one fairly informative thread on "PA vs. BMR K-member" in LT1 Tech within the last three months. And in the same time frame, there was an extensive discussion on Advanced Tech regarding facts and myths about chrome moly.
Need to "search".
Old Oct 27, 2003 | 08:59 PM
trax's Avatar
Need to "search".
Aaaah, NOW I found it... I was searching for K-member, and the thread you were talking about had "Kmember" in the title so it never came up.
Excellent thread. Looks like I'll go with BMR. Thanks guys.
Old Oct 28, 2003 | 11:23 PM
trax's Avatar
Ok, one more question, then I'll let this one sink to the bottom for good.
Does the BMR K-member shift the engine position at all? I remember reading that the PA moves it back about 1/2"-1" .
football4life
Oct 4, 2015 07:48 AM
JJOHNROE
Sep 8, 2015 05:39 PM
97blackformula
Aug 27, 2015 06:02 PM
TGGodfrey
Aug 18, 2015 06:08 PM
realistyc
Jul 28, 2015 07:32 PM
