BMR K-member question
Old May 2, 2003 | 08:08 AM
FRDnemesis's Avatar
How much of a weight savings should I see when I install my BMR K-member in comparison to my factory piece?
Thanks,
Jeff
Old May 2, 2003 | 09:08 AM
93Z4ME's Avatar
I recall reading advertisements that claim approximately 100 lb savings with k-member(with mounts), tubular control arms and special shocks. I think the k-member alone was good for 40-50lbs and 2-3" of additional header clearance. I guess when you get your old one out you can weigh it and your new one on your bathroom scale and let us all know.
Old May 2, 2003 | 09:13 AM
FRDnemesis's Avatar
I just found something on LS1 Speeds web page that says a 32lb. savings. Thats fairly descent I suppose.
Jeff
Old May 2, 2003 | 03:05 PM
mongse_1's Avatar
Expect around 35# weight savings w/ the k-member. The lower a-arms are probably about 20-25# and the uppers maybe 5#.
Old May 5, 2003 | 07:45 AM
FRDnemesis's Avatar
Are these weights that you've measured? The reason I ask is because I have heard that the bottom control arms actually weigh more than the factory pieces. I dont find that hard to believe because every factory suspension part I have replaced with an aftermarket piece so far has been significantly heavier. With the exception of the HAL shocks of course.
It will be nice to actually buy a part that is a weight savings; like the K-member.
Thanks,
Jeff
LeftoverChinese
Jan 14, 2024 03:03 PM
8T8IROC
Mar 26, 2015 09:02 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
twistedwedge
Jul 27, 2002 01:54 PM
