blue smoke whats wrong any guesses
Old Apr 17, 2007 | 05:05 PM
cr8tive ta's Avatar
is the blue smoke oil or gas i know my cars gets bad gas milage, but does anybody have any clues?
Old Apr 17, 2007 | 05:08 PM
BMWKillR's Avatar
Methinks its oil. Maybe from cylinder heads or valves. My celica does the same thing.
Old Apr 17, 2007 | 05:20 PM
LiENUS's Avatar
Colors of smoke
Blue: Oil
White: Coolant
Black: Gas
Old Apr 17, 2007 | 05:21 PM
Blue smoke is oil. The two normal sources of it getting into the combustion chamber are rings or valve seals.
Old Apr 17, 2007 | 05:24 PM
lt1 beast's Avatar
i second that, try the valve seals first there cheap but you will need to pressurize the cylinder through the sparkplug to keep your valves up.
Old Apr 17, 2007 | 06:10 PM
stereomandan's Avatar
Not true. If you do the cylinders in proper order, each piston at TDC will keep the valve from falling.
Shoebox has a procedure on his site.
Dan
Old Apr 17, 2007 | 10:40 PM
crazydavez28's Avatar
http://www.youtube.com/watch?v=xFCzZ30oKrk
what smoke do you see? i know there is a lot of black but i kinda thought i saw a little blue before all the black.
Old Apr 17, 2007 | 11:37 PM
SS RRR's Avatar
Dan
I have NEVER had luck with the TDC method. I guess it may depend on what spring compressor you use. I've always used the cheap screw type compressors and every time I would get the spring compressed it would fall into the eyebrow of the piston to where I couldn't get the locks off. This was all solved by placing the piston close to BDC, stuffing it with nylon rope and cranking the piston up to compress the rope.
Old Apr 18, 2007 | 08:27 AM
95Z28ConvtM6's Avatar
If you're getting blue smoke "only" at a cold start-up, then it is typically the valve seals. It you get blue smoke while driving, accelerating and decelerating you're probably looking at the rings.
jwade88
Jun 14, 2015 09:38 PM
dylan1303
May 22, 2015 12:24 PM
warmeck
Mar 22, 2015 06:43 PM
captcorvette
Mar 7, 2015 12:37 PM
bossco
Nov 29, 2014 10:18 AM
