blue smoke whats wrong any guesses
Shoebox has a procedure on his site.
Dan
http://www.youtube.com/watch?v=xFCzZ30oKrk
what smoke do you see? i know there is a lot of black but i kinda thought i saw a little blue before all the black.
I have NEVER had luck with the TDC method. I guess it may depend on what spring compressor you use. I've always used the cheap screw type compressors and every time I would get the spring compressed it would fall into the eyebrow of the piston to where I couldn't get the locks off. This was all solved by placing the piston close to BDC, stuffing it with nylon rope and cranking the piston up to compress the rope.
If you're getting blue smoke "only" at a cold start-up, then it is typically the valve seals. It you get blue smoke while driving, accelerating and decelerating you're probably looking at the rings.
bossco
Nov 29, 2014 10:18 AM
