Blown LT 355 Dyno Results
Old Jul 13, 2004 | 05:54 PM
n2oblkz
Guest
Posts: n/a
I just got back from TEA in Bowling Green with a budy of mine watching them dyno tune his car. It is a 1996 Z-28 with a 355. It has stock crank, Trick Flow rods, custom grind HR cam, JE dished pistons bored .30 over with CNC ported stock heads. It is running a Vortech S-trim with 10 pounds of boost through a T-56 and into a Strange 12 Bolt. The car has SMC alcohol injection and it made 572 RWHP and 511 RWTQ with 93 degree heat and 90% humidity. Just for fun, he iced down a bottle of alcohol and water and replaced what was in the container and it made 18 more RWHP with the iced water/alcohol than the fluid that was in the tank!
Old Jul 13, 2004 | 05:56 PM
Somnambulist's Avatar
Old Jul 13, 2004 | 06:12 PM
IrocSS85's Avatar
damn, all that on a stock crank? sweet. whats the comp. ratio. just curious. thats awesome though
chris
Old Jul 13, 2004 | 06:26 PM
simple's Avatar
chris
is the crank polished and oil holes drilled and chamfered?
i would almost expect those numbers with blower only tho @ 10psi....
good stuff tho, i bet that thing is a screamer
Old Jul 13, 2004 | 06:30 PM
neil350's Avatar
Awesome, thats prety much the goal with my car.
Old Jul 13, 2004 | 06:41 PM
SAR2K's Avatar
Thumbs up
Awesome #'s your buddy has there, especially with CNC'd factory LT1 heads. Now it's time to turn some serious #'s at the strip.
Steve...
Old Jul 13, 2004 | 06:42 PM
n2oblkz
Guest
Posts: n/a
Yeah, anyone would be happy with those numbers! I think that the Compression ratio is about 9.0 to 1. The crank got a good going through, it was built by Nick Norris at Nutek. I beleive that he did polish and chamfer the crank. TEA stated that their dyno is very conservative for a Dynojet. They said that most cars that run on their dyno make quite a bit more power on others. So it should be making around 600 to the tires.
Old Jul 13, 2004 | 06:43 PM
IrocSS85's Avatar
I wouldnt expect those numbers at all. Ive installed two ATI kits on LS1s and one had cam, full exh., full ind, dyno tune and he put down 480RWHP and only 434 RWTQ at 9psi. the other one only had full exh./ind. and 8lbs and put down 425RWHP. so 575 RWHP is downright awesome. whatelse is done with the car? billet fuel rails? what inj.s? what cam?
Robert95z's Avatar
Very impressive with a 355 on a stock crank
Old Jul 13, 2004 | 06:44 PM
n2oblkz
Guest
Posts: n/a
It's probably going to the strip this weekend! I'll keep you posted!
Old Jul 13, 2004 | 06:46 PM
simple's Avatar
whoops, i read it as 512 not 572rwhp , thats why i made that comment
Old Jul 13, 2004 | 06:54 PM
LT1ponykilla's Avatar
Nice numbers!
Old Jul 13, 2004 | 07:07 PM
besz28's Avatar
wow awesome #'s
Old Jul 13, 2004 | 08:19 PM
SS MPSTR's Avatar
Be careful with broad generalizations and assumptions...nonetheless, the car is making incredible power regardless of any claimed 'underrating'.
Old Jul 13, 2004 | 08:52 PM
n2oblkz
Guest
Posts: n/a
Be carefull with broadgeneralizations and assumptions...nonetheless, the car is making incredible power regardless of any claimed 'underrating.'
It's their dyno, they should know how it performs, I'm just going by what the dyno operator told me and what he has experienced and observed.
