Blown LT 355 Dyno Results
Old 07-13-2004, 05:54 PM
n2oblkz
Guest
Posts: n/a
I just got back from TEA in Bowling Green with a budy of mine watching them dyno tune his car. It is a 1996 Z-28 with a 355. It has stock crank, Trick Flow rods, custom grind HR cam, JE dished pistons bored .30 over with CNC ported stock heads. It is running a Vortech S-trim with 10 pounds of boost through a T-56 and into a Strange 12 Bolt. The car has SMC alcohol injection and it made 572 RWHP and 511 RWTQ with 93 degree heat and 90% humidity. Just for fun, he iced down a bottle of alcohol and water and replaced what was in the container and it made 18 more RWHP with the iced water/alcohol than the fluid that was in the tank!
Old 07-13-2004, 05:56 PM
Somnambulist's Avatar
Somnambulist is offline
Old 07-13-2004, 06:12 PM
IrocSS85's Avatar
damn, all that on a stock crank? sweet. whats the comp. ratio. just curious. thats awesome though
chris
IrocSS85 is offline
Old 07-13-2004, 06:26 PM
simple's Avatar
chris
is the crank polished and oil holes drilled and chamfered?
i would almost expect those numbers with blower only tho @ 10psi....
good stuff tho, i bet that thing is a screamer
simple is offline
Old 07-13-2004, 06:30 PM
neil350's Avatar
Awesome, thats prety much the goal with my car.
neil350 is offline
Old 07-13-2004, 06:41 PM
SAR2K's Avatar
Thumbs up
Awesome #'s your buddy has there, especially with CNC'd factory LT1 heads. Now it's time to turn some serious #'s at the strip.
Steve...
SAR2K is offline
Old 07-13-2004, 06:42 PM
n2oblkz
Guest
Posts: n/a
Yeah, anyone would be happy with those numbers! I think that the Compression ratio is about 9.0 to 1. The crank got a good going through, it was built by Nick Norris at Nutek. I beleive that he did polish and chamfer the crank. TEA stated that their dyno is very conservative for a Dynojet. They said that most cars that run on their dyno make quite a bit more power on others. So it should be making around 600 to the tires.
Old 07-13-2004, 06:43 PM
IrocSS85's Avatar
I wouldnt expect those numbers at all. Ive installed two ATI kits on LS1s and one had cam, full exh., full ind, dyno tune and he put down 480RWHP and only 434 RWTQ at 9psi. the other one only had full exh./ind. and 8lbs and put down 425RWHP. so 575 RWHP is downright awesome. whatelse is done with the car? billet fuel rails? what inj.s? what cam?
IrocSS85 is offline
Robert95z's Avatar
Very impressive with a 355 on a stock crank
Robert95z is offline
Old 07-13-2004, 06:44 PM
n2oblkz
Guest
Posts: n/a
It's probably going to the strip this weekend! I'll keep you posted!
Old 07-13-2004, 06:46 PM
simple's Avatar
whoops, i read it as 512 not 572rwhp , thats why i made that comment
simple is offline
Old 07-13-2004, 06:54 PM
LT1ponykilla's Avatar
Nice numbers!
LT1ponykilla is offline
Old 07-13-2004, 07:07 PM
besz28's Avatar
wow awesome #'s
besz28 is offline
Old 07-13-2004, 08:19 PM
SS MPSTR's Avatar
Be careful with broad generalizations and assumptions...nonetheless, the car is making incredible power regardless of any claimed 'underrating'.
SS MPSTR is offline
Old 07-13-2004, 08:52 PM
n2oblkz
Guest
Posts: n/a
Be carefull with broadgeneralizations and assumptions...nonetheless, the car is making incredible power regardless of any claimed 'underrating.'
It's their dyno, they should know how it performs, I'm just going by what the dyno operator told me and what he has experienced and observed.
Quick Reply: Blown LT 355 Dyno Results
