blowing out white smoke
Old Mar 28, 2007 | 10:23 AM
  #16
njenson's Avatar
yea id say that looks more blue than white
Also, as for the whole white smoke thing... any vehicle will blow white smoke when the outside temperature is pretty cold... although i do live in mn so what is considered cold may differ from my opinion
Old Mar 28, 2007 | 10:45 AM
  #17
vdubois's Avatar
You could always do a compression test on the motor and a pressure test on the cooling system. You could guess as to what it is all day long. Is there water in the oil or on the cap of the oil fill. Does it smoke all the time. Can you smell the smoke.
Old Mar 28, 2007 | 11:05 AM
  #18
Executioner2k5's Avatar
i can smell the smoke when it does it an it smells really bad i would do a comp test or test the colling but i dont have the stuff to test it an im not looking to lose my car to the shop right now havent check for water in the oil yet
Old Mar 28, 2007 | 01:41 PM
  #19
95LT1conv's Avatar
oil seeps through the seals and sits in the valve after being shut down. when you start it again, the oil in the valves is burned. where the heads new w/ the motor or are they old, untouched heads?
Old Mar 28, 2007 | 02:20 PM
  #20
ChevalierSS's Avatar
looks like valve seals to me. if it only puffs blue on start up after it has sat for awhile, I wouldn't worry about it.
They aren't that hard to replace, a little time consuming, but not difficult.
Old Mar 28, 2007 | 02:44 PM
  #21
old heads just fixed same valves valve springs etc
Old Mar 28, 2007 | 03:31 PM
  #22
TobyZ28's Avatar
Definatly blue smoke. White smoke from a blown headgasket would be billowing out way thicker.
Old Mar 28, 2007 | 03:35 PM
  #23
95LT1conv's Avatar
just replace the seals when you can. nothing to be overly concerned about
Old Mar 28, 2007 | 03:45 PM
  #24
i know nothing about heads and valves lol
IndyZman
Oct 22, 2015 02:17 PM
Hal Fisher
Sep 30, 2015 09:03 PM
drt
Sep 27, 2015 04:39 PM
frankrizz
Sep 23, 2015 04:21 PM
jackpawt883
Sep 10, 2015 08:53 PM
