trick flow elbow ?
Old Mar 28, 2007 | 12:08 PM
jer4251's Avatar
trick flow elbow ?
i have a trickflow elbow. it comes with the hole on the passenger side of it for the one sensor. on the drivers side of the elbow your suppose to drill a little hole for a tiny hose.
my question is. whats the little hose? and does it matter then i didnt drill the hole, i just left the hose sitting out it the open. is it going to cause any problems?
thanks
Old Mar 28, 2007 | 12:35 PM
94lt1redta's Avatar
Not entirely positive but I think it's the optispark vent. If so, I would imagine it is bad to have it in the open with the possibility of sucking particles inside the opti. Do a search, I'm sure there is something on it.
Old Mar 28, 2007 | 12:39 PM
Javier97Z28's Avatar
Moderator
Optispark vent.
Open the hole and run the hose.
Old Mar 28, 2007 | 12:43 PM
jer4251's Avatar
wouldnt the engine be sucking air from the opti then? im sure the motor has a more forceful sucking power to it to over take the sucking of the opti.
Old Mar 28, 2007 | 12:48 PM
Moderator
The point is that it's a fresh air line for the opti, it's part of the venting system for the opti.
Without it you are defeating the purpose of having a vented opti. Without it you are sucking in dirty air into the opti, which in turn gets pulled into the motor.
Put the line on.
Old Mar 28, 2007 | 12:49 PM
jer4251's Avatar
thanks.
Old Mar 28, 2007 | 04:11 PM
F8T LT1's Avatar
I have the TF elbow the small hole is 100% for the opti vent
Formula Steve
Sep 19, 2023 08:31 AM
football4life
Oct 4, 2015 07:48 AM
Daluchman1974
Sep 11, 2015 06:12 AM
Slayer
Aug 17, 2015 03:55 PM
colts0455
Jul 24, 2015 04:51 PM
