Blow by
Old Sep 8, 2008 | 12:03 AM
jeremy stanke's Avatar
Blow by
well a friend of mine who is a small time mechanic said that he thinks my motor has blow by. it is hardly even smoking. he had to take off the oil filler to see it, there is no smoke coming from the exhaust either. my question is this, if it really is blow by, how long will it last until the motor goes and how much power am i losing?
Old Sep 8, 2008 | 05:12 AM
Blowby is the combustion products blowing past the rings and filling the crankcase. Up to a point, the PCV system removes those vapors, and they end up in the intake manifold where they are run through the combustion chamber again.
If you have excessive blowby, it isn't going to cause the exhaust to smoke. Its going to overload the PCV system, and the excess will flow out the passenger side valve cover, through the hose that connects it to the throttle body. Typically, you will see oil start to build up in the hose, in the top of the throttle body under the removable cover, and eventually soaking the intake with oil starting at the throttle body.
Check all those locations for oil buildup. Pull the oil fill cap off (engine running) and look for smoke coming out of the fill tube. In severe cases you can feel a "puffing" out the oil fill tube, or even hear it.
Old Sep 8, 2008 | 10:43 AM
twcblackhand6970's Avatar
not to thread jack, but I have some smoke coming out of my oil filler hole when I take the cap off, is it normal to have some smoke? and my pvc hose has some oil in it, but not enough to flood the intake and come out the tb. So is that excessive or normal?
Old Sep 10, 2008 | 01:00 AM
? Anyone
Old Sep 10, 2008 | 02:34 AM
SS RRR's Avatar
I assume your PCV system is still on the vehicle? If you're seeing smoke or can feel positive pressure coming out of your oil fill hole then, as Fred said your PCV system may be overloaded. Check your PCV valve to make sure it is not clogged. The breather tube that connects from the pass. side valve cover to the TB is neutral flowing. When an engine is not seeing vacuum (ie under acceleration) blow-by is then channeled through this hose and it is quite possible oil can make its way into the plenum. This has been a common problem for LT1's which do not experience excessive blow-by. Every engine generates blow-by. The best way to know if you are truly experiencing excessive blow-by is to have a leakdown test done on each cylinder.
Old Sep 10, 2008 | 11:19 PM
so how do i check to see if my PVC system is overloaded? I don't really feel any pressure, but I can see minor buffs.
Old Sep 11, 2008 | 05:17 AM
Now that you have highjacked the thread , have you checked the operation of your PCV valve?
Old Sep 11, 2008 | 04:21 PM
i wasn't expecting to keep going, but no, I don't know how to check operation of the valve.
drt
Sep 27, 2015 04:39 PM
z28newbie
Sep 9, 2015 10:26 AM
z28newbie
350350
14
Aug 11, 2015 12:03 PM
96SilverRam
Aug 9, 2015 04:15 PM
