Blocking the EGR and questions on performance?
Old Mar 23, 2004 | 08:24 AM
Mike TexaSS's Avatar
I found out last night that all my runs since port and polishing my LT4 intake and adding a AS&M 58mm TB. Havent ment anything. Ive been running with a huge intake leak at the back of the intake!
My stock EGR valve had lost one of the 13mm nuts and the other one had almost fallen off too. So needless to say vacume leaks are not a motor's best friend.
How much can a massive vacume leak effect 1/4 mile performance. It seems as if a car would run really LEAN with the extra air comming in that the MAF does not read.
How do I block off the EGR? Is there a kit from DAL?
What do i do with the open vacume line on the thing that the EGR valve's vacume line goes too?
What about programming? Do i need to turn off the EGR in the CPU? I assume so.
Is there anything else I need to know?
Old Mar 23, 2004 | 08:30 AM
LT4 EGR block-off plate GM p/n 10054880.
Plug the fitting with a rubber vacuum cap or remove the fitting from the manifold and put a pipe plug in it.
Old Mar 23, 2004 | 08:36 AM
Thats exzactly what i was thinking! With a 409 LT4 with a hot cam i should have no ill effects of blocking off the EGR?
Also I am very experienced with LT1EDIT should I alsoshould i tunrn off the EGR in the PCM.
Old Mar 23, 2004 | 08:59 AM
Just checked your website its GREAT! lots of pics and tech tips!
Old Mar 23, 2004 | 09:01 AM
Since the factory LT4 did not use an EGR valve, you will probably be ok. You may or may not set a code, but if you do, you can shut off monitoring of the code with the programming.
Old Mar 23, 2004 | 09:04 AM
The more i look into it im better off just betting a new EGR Valve. Because id still need to block off the other EGR port and the hole on my passenger side header.
Old Mar 23, 2004 | 09:43 AM
Chris'SS #2152's Avatar
Here is a company with a complete block off kit.
http://www.mycamaroz28.homestead.com/
Block it off. mine kept coming loose as well.
Old Mar 23, 2004 | 06:50 PM
WhoomWhaatWhaah's Avatar
My car runs cooler without the egr. I got some very nice block plates from tpis for about 20 bucks
Old Mar 23, 2004 | 07:08 PM
Xride's Avatar
The GM LT4 ones are only 8 at the dealer.
Old Mar 30, 2004 | 10:49 PM
when I tried the dealer they looked at me like I was stupid(whats and EGR?) Maybe cause I live in California
Old May 7, 2004 | 01:54 PM
drewstealth's Avatar
Can i use the LT4 EGR block plate to block off my EGR? I can just leave the valve attached right? As long as i just put a plate on the back of the intake where the tube is comeing out of and program the EGR out of the computer i should be fine. Is this correct?
Also if i'm just cruising and my EGR is not blocked off and the tube that runs to the back of my intake is just open will i be able to smell fumes comeing from there? Because my car really smells bad when i'm at a stop and while cruising.
Old May 9, 2004 | 09:29 PM
Eff's Avatar
Eff
mine didnt throw a code when i removed it, then again, my engine didnt throw a code at all when i did heads/cam/ 383 ! EGR !air !cat and every other imagineable bolt on, my car is just weird.
Old May 9, 2004 | 10:25 PM
You can't leave the pipe hanging open. It's like a big exhaust leak.
Old May 9, 2004 | 11:15 PM
CrAkD X 95TA's Avatar
you shouldnt block off the EGR if you have to pass emissions correct?
Old May 10, 2004 | 02:57 PM
So the pipe that is hanging from the back of the intake is that sucking in air or is it letting out air? Also would this cause my really rich condition?
