Blocking the EGR and questions on performance?
Old May 10, 2004 | 03:54 PM
  #16
Originally posted by drewstealth
So the pipe that is hanging from the back of the intake is that sucking in air or is it letting out air? Also would this cause my really rich condition?
It's an exhaust leak. Any exhaust leak is going to upset the O2 readings on that side. Exhaust will go out or air can go in, depending on the backpressure at the time.
Old May 10, 2004 | 04:21 PM
  #17
drewstealth's Avatar
I'm not sure how the exhaust will go in or out because it is hooked up to the back of the intake and nothing else. I have the Hooker LT's with no egr.
Old May 10, 2004 | 04:40 PM
  #18
When I read your first post about it, it sounded like it was attached to the exhaust manifold and not the intake. Now, I notice that you next said that it was attached to the intake. Ok, so no exhaust leak, since you have nothing coming from the header. The EGR valve must be disabled or removed and blocked off or you will have a big vacuum leak through your dangling pipe and the valve. You can leave the pipe hanging there if you want.
Old May 10, 2004 | 05:02 PM
  #19
Somebody told me i can leave the Valve there and not have to block it off. Is this true? Can i just put a block off plate where the tubing is hanging from and program the egr out and be okay? Or do i have to block off the valve also? Would this Vacume leak cause me to run rich?
Old May 10, 2004 | 05:19 PM
  #20
The EGR valve must be disabled or removed and blocked off ...
So, yes you can leave the valve there, but it must be disabled! (no vacuum to the valve) You would essentially be using the valve as a block off plate.
Once the valve is disabled, the tubing plays no part in anything (in your case). You can do whatever you want with it.
Program it out of the PCM to keep any codes from coming up.
An air (vacuum) leak through the EGR could cause a rich condition.
Old May 10, 2004 | 05:44 PM
  #21
Okay thanks for all the help shoebox. So i just gotta get that programed out of my pcm and get a blockoff plate for the tube part and i'll be all set. Hopefully that will fix my rich running condition.
Old May 10, 2004 | 07:46 PM
  #22
Eff's Avatar
Eff
Originally posted by CrAkD X 95TA
you shouldnt block off the EGR if you have to pass emissions correct?
no, it shouldn't matter. the CAT is the last word in emmissions. You don;t need no stinking EGR And if your car is 96 or newer, No engine lights = PASS
F'n1996Z28SS
Aug 23, 2023 11:19 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
cmdeshon
Dec 27, 2014 10:06 AM
Jul 4, 2005 05:00 PM
