Block prep before installing heads?
Old Jun 8, 2004 | 06:45 PM
Black94mula's Avatar
Should I just wire wheel brush the block and then brake clean it?
Old Jun 8, 2004 | 07:24 PM
5.0THIS's Avatar
You need to be sure all of the old gasket is off of there, so whatever it takes. Some scotchbright usually works well for that, and before that a razor blade if there are any remnants of the old gasket still there. try to wipe out the cylinders as best you can when done. And since inevitably some stuff still gets in the oil, it's always a good idea to do an oil change not long after completing your engine work.
Old Jun 8, 2004 | 07:36 PM
BlackbirdWS6's Avatar
yea took a razor blade to mine to get all the old gasket off, then continued to use brake cleaner to get whatever was left. I did spray some wd40 in the cylinders after i gave them a quick wipe down after everything else was cleaned just for some little mental insurance. heh
MadMav
Feb 6, 2015 11:02 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
F(ast)-body
Feb 26, 2003 09:05 AM
yosshimura
Aug 12, 2002 06:47 AM
