Block drain plug won't go all the way in
Old Feb 28, 2004 | 06:38 PM
JJ's95B4C's Avatar
I was putting the block drain plug and I can see one thread still. Its not fully touching the block. I've tightened it as far as possible, but it won't go anymore. Is this ok, or is there somethign wrong? Will coolan drain out of that hole if its not fully in?
Old Feb 28, 2004 | 06:43 PM
It should not go all the way in. It is a tapered plug. It should only be tightened enough to where it does not leak.
Old Feb 29, 2004 | 04:47 PM
arnie's Avatar
Re: Block drain plug won't go all the way in
Are you familiar with pipe thread. You've already screwed it in WAY farther than necessary.
Old Feb 29, 2004 | 09:17 PM
JJ's95B4C's Avatar
Re: Re: Block drain plug won't go all the way in
No? Please enlighten me!
Old Mar 1, 2004 | 02:08 AM
Mtrhds94Z's Avatar
Re: Re: Re: Block drain plug won't go all the way in
Simply put pipe threads[as are the block drain plugs
are tapered, designed to get TIGHTER the farther in you thread it..
Just snugging it with a little teflon tape etc is good..
You risk cracking the casting[ though I doubt you would crack the side of the engine block..] by 'overtightening'..
Magenta_Hearts
Mar 29, 2017 08:54 PM
eanhl2004
Apr 4, 2015 12:01 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Sandersen511
Jan 13, 2015 03:49 PM
