Block
Old Jul 20, 2005 | 12:26 AM
'94 Red Dragon's Avatar
Block
I have a police car LT1 block. Is it a 2 bolt main or a 4 bolt main.
I plan on getting 600HP out of it, and if it is 2 bolt main can it handle this hp and big nitrous sprays.
Please Help
Old Jul 20, 2005 | 01:03 AM
JP94Z's Avatar
Re: Block
All the sources I can find say only the Corvettes had the 4-bolt, and that the 9C1 Caprice was not an exception.
I will leave your other question to those with more experience.
Old Jul 20, 2005 | 02:42 AM
camarokid24's Avatar
Re: Block
From what I understand the corvette and replacement lt1 motors from GM were 4 bolt. I have a B4C "specail service package" Wich is basicly a discounted z28 with camaro bages instead of z28 badges that GM gave for Law enforcement.
Old Jul 20, 2005 | 08:28 AM
Re: Block
Please Help
The blocks were no different than any other ones. I would assume you are going to be tearing it down before performing mods to get it to 600 hp, so you will find out if it is 2 or 4 bolt mains.
Old Jul 20, 2005 | 10:38 AM
LameRandomName's Avatar
Re: Block
I would be shocked & surprised if it was anything other than a 2-bolt main.
As to what it will handle, that is more dependant on block prep than bolt numbers. You CAN get it converted to a 4-bolt setup, and if you do you should choose a splayed setup.
However, if you do a GOOD block prep and use studs, you shouldn't have any problem at all with 600hp and 7000+ rpm.
In addition to doing good block prep, which means a line bore and fine tuning your oil system, you also want a high quality crank. At the 600hp level you should look carefully at the Callies Dragonslayer. Howards has some PM rods for $599 that are only 585 grams and support 800hp. Balancing is prehaps the most important, and use a high quality balancer/damper.
Beyond that, the single most important thing you can do is to watch your DCR so that you stay out of detonation. Even a poorly done bottom end will tolerate a lot of rpm and power as long as you don't get into detonation.
The best bottom end in the world won't survive detonation for long.
Old Jul 20, 2005 | 11:59 PM
Re: Block
How much does it cost to prep the block
How much does it cost to convert to a 4bolt main
GREEN3112
Feb 10, 2019 09:19 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
heus
Sep 8, 2015 12:01 PM
