Block
Re: Block
From what I understand the corvette and replacement lt1 motors from GM were 4 bolt. I have a B4C "specail service package" Wich is basicly a discounted z28 with camaro bages instead of z28 badges that GM gave for Law enforcement.
Re: Block
Originally Posted by '94 Red Dragon
I have a police car LT1 block. Is it a 2 bolt main or a 4 bolt main.
I plan on getting 600HP out of it, and if it is 2 bolt main can it handle this hp and big nitrous sprays.
Please Help
Please Help
Re: Block
I would be shocked & surprised if it was anything other than a 2-bolt main.
As to what it will handle, that is more dependant on block prep than bolt numbers. You CAN get it converted to a 4-bolt setup, and if you do you should choose a splayed setup.
However, if you do a GOOD block prep and use studs, you shouldn't have any problem at all with 600hp and 7000+ rpm.
In addition to doing good block prep, which means a line bore and fine tuning your oil system, you also want a high quality crank. At the 600hp level you should look carefully at the Callies Dragonslayer. Howards has some PM rods for $599 that are only 585 grams and support 800hp. Balancing is prehaps the most important, and use a high quality balancer/damper.
Beyond that, the single most important thing you can do is to watch your DCR so that you stay out of detonation. Even a poorly done bottom end will tolerate a lot of rpm and power as long as you don't get into detonation.
The best bottom end in the world won't survive detonation for long.
