BLM's in cell 17 low????
Old Jul 21, 2007 | 10:16 AM
mrmint69's Avatar
I checked the BLM's and the cell 16 stays at 127-128, cell 17 stays right at 116 (i assume this is bad) & cell 18 stays at 123-124. I am curious if these are out of specs & what to do to fix them.
Old Jul 21, 2007 | 10:51 AM
Cells 17 and 18 appear to be mathematically derived from the other Cells. As best I can tell, Cell 17 is used primarily for deceleration. I wouldn't worry about them.
You need to get the values for as many of the closed loop Cells (01-15) as you can. A few of them may be driving the mathematic cells.
Old Jul 21, 2007 | 05:27 PM
stereomandan's Avatar
I don't worry about cell 17, since it is normally used when you decelerate, like Injuneer said. Normally, if your other partial throttle cells have long term BLM's close to 128, then cell 17 falls somewhat in line too.
Dan
Old Jul 24, 2007 | 12:21 AM
mrmint69's Avatar
I ran the car today and got reading for cell 1-15 and they varied from 109-123 for each one. None where close to the cells 16-18 that are are much higher on average like 119-128.
Old Nov 23, 2007 | 06:32 PM
C_Rules's Avatar
i hear a lot about cell 16. someone care to elaborate where this cell is?
Old Nov 23, 2007 | 10:37 PM
mrmint69's Avatar
Cell 16 is the idle cell. Doesn't tell much and 17 and 18 are for a cold start up on high and low loads.
Old Nov 24, 2007 | 10:26 AM
17 and 18 are also used under various circumstances when the engine is fully warmed up.
Ericksd
Jan 20, 2016 06:07 PM
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
KYWes
Sep 26, 2015 08:49 AM
jackpawt883
Sep 10, 2015 08:53 PM
