Blinker Arm Broken
Old Sep 12, 2003 | 05:22 PM
Tails's Avatar
Blinker Arm Broken
How do replace the blinker arm going into the steering column? Do I have to take the steering whell off to get the cover off?
It looks like one of the two brackets that hold the arm broke off. Can I replace just this part or what? Thanks.
Tails
Old Sep 12, 2003 | 09:51 PM
If it was not the lever that broke, you will have to go into the column to replace the switch (#23).
Column
Old Sep 29, 2003 | 02:14 PM
snorkelface's Avatar
I need to bring this one back up. My Blinker stalk (lever) just swings freely up and down without engaging the blinker. I have the column taken apart, and notice that a little arm that connects the turn signal switch (#12 in that blow up) to the lever is broken. Is #23 (SWITCH ASM, PIVOT &(PULSE)) also what I need to replace? Thanks for the help!
Old Sep 29, 2003 | 02:18 PM
Lightbulb
Actually, looking at the diagram again, #11 (ARM ASM, SIGNAL SWITCH) is what I found broken. How would I determine if the #23 part was also broken. I already went ahead and got a new turn signal switch (#12)
Old Sep 29, 2003 | 05:12 PM
Tails's Avatar
I just ended up replacing #23 and it fixed it. Although I need to take it back apart and fix my damn high/low beams..
Tails
Old Sep 29, 2003 | 05:26 PM
Tails
What happened to your high/low beams?
So, the #11 wasn't broken in yours, or does #23 come with it?
Also, the little bearing came out, and I find are almost impossible to get all of them back in. Did you have any troubles with this?
Old Sep 29, 2003 | 06:05 PM
notstock4long's Avatar
I think I am missing either an 11 or 21. By stalk just flops back and forth. But it goes up and down just fine, even though the signals don't work. My brights don't work either.
Stephen68
Parts Wanted
Sep 27, 2015 06:42 PM
autoxr166
Sep 25, 2015 04:21 PM
mmf_1013
Sep 12, 2015 08:56 PM
Toxintwins
Sep 11, 2015 11:13 AM
maverickmk
Sep 1, 2015 09:17 PM
