Blinker Arm Broken
Blinker Arm Broken
How do replace the blinker arm going into the steering column? Do I have to take the steering whell off to get the cover off?
It looks like one of the two brackets that hold the arm broke off. Can I replace just this part or what? Thanks.
Tails
Tails
I need to bring this one back up. My Blinker stalk (lever) just swings freely up and down without engaging the blinker. I have the column taken apart, and notice that a little arm that connects the turn signal switch (#12 in that blow up) to the lever is broken. Is #23 (SWITCH ASM, PIVOT &(PULSE)) also what I need to replace? Thanks for the help!
Actually, looking at the diagram again, #11 (ARM ASM, SIGNAL SWITCH) is what I found broken. How would I determine if the #23 part was also broken. I already went ahead and got a new turn signal switch (#12)
Originally posted by Tails
I just ended up replacing #23 and it fixed it. Although I need to take it back apart and fix my damn high/low beams..
Tails
Tails
So, the #11 wasn't broken in yours, or does #23 come with it?
Also, the little bearing came out, and I find are almost impossible to get all of them back in. Did you have any troubles with this?
autoxr166
Sep 25, 2015 04:21 PM
Toxintwins
Sep 11, 2015 11:13 AM
