blew a pushrod
Old Feb 18, 2005 | 04:47 PM
  #31
karl81talt1's Avatar
Re: blew a pushrod
If your car was overheating it probably blew a head gasket. Which if done right would fill the cylinder with coolant and very possibly hydolock the motor which could at the very least snap a couple of push rods. just hope and pray that the pistons and rods are still intact. good luck and i say just rip it apart and figure out how to put it back together later
Old Feb 19, 2005 | 05:49 AM
  #32
slopokrodrigez's Avatar
Re: blew a pushrod
Hydrolock won't effect push rods. It will however effect the connecting rods. I think Shoebox explained everything that needs to be said. Jeremy, if you are curious, pull the intake and heads off and look in the piston bores. BUT again I agree with Shoe, get a professional or consider at least a short block.
Old Feb 19, 2005 | 06:38 AM
  #33
94m5's Avatar
Re: blew a pushrod
I concur,
Jeremy, Where are you located? If it's in central or, AROUND central Illinois, I would be more than happy to help you out.
Old Feb 22, 2005 | 03:43 AM
  #34
JeremyZ28's Avatar
Re: blew a pushrod
haven't had any time to look at it yet, I am in york, pa.
Old Feb 22, 2005 | 04:16 AM
  #35
JeremyZ28's Avatar
Re: blew a pushrod
Originally Posted by Dave88LX
Not sayin you're WRONG, but are you saying that his rod broke in half, shattered the piston, sent bits and pieces of that into the oil pan, and now 1/2 the connecting rod is sitting there flapping around hitting everything? Because if he has half a connecting rod, then there's a much more serious problem, so I feel that your theory is wrong.
I'd be *tempted* to think if he has pieces of a piston and half a rod in pieces in his pan he'd have clogged up the oil filter pretty well, and really known something went *bang*.
Not saying you're wrong, I just don't think you're right.
Oh, and this is the sound of metal-on-metal...piston hitting head This is when I spun my rod bearing. Right Click -> Save As.
http://paradox.shacknet.nu/dave88lx/formula/clack2.mpg
http://paradox.shacknet.nu/dave88lx/formula/clack1.mpg
It doesn't sound like that at all, mine is more of just a clicking noise.
Old Feb 26, 2005 | 06:22 PM
  #36
JeremyZ28's Avatar
Re: blew a pushrod
worked on it some today, took out the alternator and removed both the valve covers, the driver side a push rod came loose from the roller rocker, wasn't connected under it. took out the push rod seemed fine, wasn't broken/bent so I fixed that, on the passenger side the rods/rockers/springs all looked fine. Ran the car for a few mins, the smoke coming out of the drivers side engine bay isn't coming out anymore. I'll run the car for a good 30mins tommorrow and see what happens. friend said with the push rod its very rare but can happen where something hits wrong or a valve sticks and the push rod gets knocked loose.
Old Mar 13, 2005 | 02:08 AM
  #37
JeremyZ28's Avatar
Re: blew a pushrod
car runs but sluggish, all the pushrods are fine. So I guess i'm going to pull the intake and see how hard it is to get these heads off. I think I smelled coolant burning when I had it running, not a good sign
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
