BLEW MY "FORGED" PISTON!! Pics..
Old Aug 14, 2006 | 11:54 AM
EVERESTZ28's Avatar
One stock injector stopped working and caused one piston to burn in a nitrous pass.
I already have a set of 50 lbs injectors.
What happens if I install 50 lbs injectors in my 396 with stock tuning?
i will remove the "bulletproof" word at my sign.
Old Aug 14, 2006 | 12:09 PM
SStrokerAce's Avatar
Re: BLEW MY "FORGED" PISTON!! Pics..
See that little eyebrow in the piston top? Well that says that the pistons were installed backwards. The reliefs are made to be on the lifter valley side of the block!
It also looks like some MEAN detonation because there is some serious spatter from melted aluminum along with the broken ringland. I'm guessing that hot spot formed there because the piston was in backwards, that would put that part of the piston right below the plug, so it got VERY hot there.
Bret
Old Aug 14, 2006 | 01:15 PM
EVERESTZ28's Avatar
What about the injectors?
Old Aug 14, 2006 | 01:16 PM
They are the least of your problems.
Old Aug 14, 2006 | 07:45 PM
MachinistOne's Avatar
Not trying to rag on you, but if you had checked piston to valve clearance you would have seen this problem, and been able to correct it.
Always measure twice, cut once...or in this case mock up and check everything before your final assembly.
Old Aug 14, 2006 | 07:52 PM
marshall93z's Avatar
I know someone that installed some backwards a little while back!
Old Aug 14, 2006 | 08:44 PM
speed_demon24's Avatar
Can you post who built your motor so we all know who not to buy a motor from?
Old Aug 14, 2006 | 08:45 PM
Hybrid86Z's Avatar
werd
Old Aug 14, 2006 | 08:53 PM
TransAm396's Avatar
OUCH...you should go back to the builder and rip his head off....
Old Aug 14, 2006 | 09:31 PM
Heatmaker's Avatar
Advanced Member
Wow, sorry to hear/see that man... good luck.
Old Aug 14, 2006 | 09:42 PM
kainZ's Avatar
I don't know the guy, and maybe it was a builder... (no offense to the guy who started this post) but what makes you guys think that he didn't just install them backwards himself? We all make mistakes, and when we don't do things like double/tripple check, they tend to have catastrophic concequences. If it was his builder, I'm sure he'll share, and be getting a free rebuild. But if not, I'm sure he will check the things MachinistOne and SStrokerAce mentioned next time. Sometimes lessons hurt. We've all been there in one way or another.. But no need to get the mob together for a lynching..
Old Aug 15, 2006 | 12:50 AM
OneFlyn95z28's Avatar
FLAME ON THE PISON BABY! I have not seen that much detonation since a guy had his Fuel Sol plug
Old Aug 15, 2006 | 04:04 AM
30696bird's Avatar
Very true!!
Old Aug 15, 2006 | 06:44 AM
SS RRR's Avatar
it probably won't run. or run very well at least.
Old Aug 15, 2006 | 07:43 AM
Sweetred95ta's Avatar
So were those small valve reliefs cut by the pistons themselves? Also, is that rub mark on the underneath of the piston from the rod? double
