Bleeding System...quick Question
Old Apr 9, 2008 | 03:59 PM
SATANAZ666's Avatar
Ok Im about to replace the temp switch on the drivers side head........Im just going to unscrew the old one and quickly screw in the new one.
Do I have to bleed the system????
also I bleed it After I turn off the engine right??
Ive done this before but its been a while.
Old Apr 9, 2008 | 04:09 PM
JAB's Avatar
JAB
You bleed it with the engine running. Unscrew both screws and wait for coolant to start streaming out, then close them.
Old Apr 9, 2008 | 04:22 PM
If you do it fast enough, you probably won't have to worry about bleeding it at all. Any air that gets in will be purged in a few heat/cool cycles.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
Hurin
Dec 13, 2014 07:38 PM
