Bleeding McLeod Master
Old Jul 31, 2003 | 01:28 PM
mightymex69's Avatar
Just installed a new McLeod adj. master but there are no bleeder screws ANYWHERE!!!!!
Anyone out there have any ideas on how to bleed this dam thing??
By the way if it helps its a '97 TA 6speed
Old Jul 31, 2003 | 01:52 PM
I've helped install the McLeod master on an LS1, but the LS1 has a bleeder valve on the slave cylinder. Even with that bleeder, the master would not bleed on the car. It had to be "bench bled" (off the car) using a vacuum pump.
Formula Steve
Sep 19, 2023 08:31 AM
G-BODYT56
Jan 14, 2022 11:14 PM
Quickss96
Jan 29, 2016 05:56 PM
1bad427ls1
Sep 23, 2015 01:12 AM
Daluchman1974
Sep 11, 2015 06:12 AM
