Bleeding McLeod Master
Just installed a new McLeod adj. master but there are no bleeder screws ANYWHERE!!!!!
Anyone out there have any ideas on how to bleed this dam thing??
By the way if it helps its a '97 TA 6speed
I've helped install the McLeod master on an LS1, but the LS1 has a bleeder valve on the slave cylinder. Even with that bleeder, the master would not bleed on the car. It had to be "bench bled" (off the car) using a vacuum pump.
Formula Steve
Sep 19, 2023 08:31 AM
