Bleeding the heater core lines..
Old Feb 20, 2003 | 10:22 PM
95BlackTA's Avatar
Ok I tried to do that heater core flush...couldnt get one of the hoses off...well anyways, the one hose i put back on was leaking coolant, so i had to go back and put it on the right way. Well how exactly do I bleed the lines? I know theres those brass bleeder valves. Do I open them, turn on the heater and then close them or what?
Old Feb 20, 2003 | 11:23 PM
In your case, I would just wait until the engine is at operating temp and crack the bleeders open until you see nothing but a steady stream of coolant with no bubbles. A more detailed procedure for the system flush and fill is on my Tech Page.
Old Feb 21, 2003 | 12:22 AM
95BlackTA's Avatar
where are you gonna "see" the coolant going through?
Old Feb 21, 2003 | 08:03 AM
You will actually see coolant coming out of the bleeder screw, since you are opening the system with it.
Formula Steve
Sep 19, 2023 08:31 AM
1bad427ls1
Sep 23, 2015 01:12 AM
Fatdog2
Sep 16, 2015 11:04 PM
Pwilson59
Sep 3, 2015 08:47 PM
ducttape1975
Jul 10, 2015 06:29 PM
