Bleeding the heater core lines..
Ok I tried to do that heater core flush...couldnt get one of the hoses off...well anyways, the one hose i put back on was leaking coolant, so i had to go back and put it on the right way. Well how exactly do I bleed the lines? I know theres those brass bleeder valves. Do I open them, turn on the heater and then close them or what?
In your case, I would just wait until the engine is at operating temp and crack the bleeders open until you see nothing but a steady stream of coolant with no bubbles. A more detailed procedure for the system flush and fill is on my Tech Page.
Formula Steve
Sep 19, 2023 08:31 AM
ducttape1975
Jul 10, 2015 06:29 PM
