bleeding the coolant- what am i doing wrong here?
Old May 17, 2004 | 08:22 PM
nfa's Avatar
nfa
I got a needle valve and clear tubing from home depot to bleed the air out of my coolant (i didnt bleed after doing the flush this spring). Ok, so i:
1) have the rad cap open
2) turn motor on and let it warm up with the heater set on high
3) after it is warm, i open up the bleed screw on top of the thermostat
a bit of fluid is being expelled from the tubing attached to my bleeder, but not a steady stream like in the pictures ive seen from some websites showing how to do this procedure. the thing that worries me the most is that A LOT of coolant is gushing out of the rad cap...
is this normal? what am i doing wrong here?
mike.
Old May 17, 2004 | 09:04 PM
Spinner's Avatar
Close the cap to bleed it. It wont shoot out without pressure, and it wont pressureize without a cap.
Old May 17, 2004 | 10:15 PM
nfa's Avatar
nfa
doh... i feel like a dummy now.
im going to try it again tomorrow after work!
thanks for the advice.
Formula Steve
Sep 19, 2023 08:31 AM
Aaront810
Aug 29, 2020 09:34 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
fift5
11
Oct 1, 2015 10:31 AM
1bad427ls1
Sep 23, 2015 01:12 AM
