Bleeding the Coolant System
Old Aug 8, 2014 | 09:14 PM
  #16
nikko's Avatar
Unhappy Re: Bleeding the Coolant System
I'm having the same problem even though I have worked on cars for many years I never had to deal with these bleeder stuff. Also what is the opti spark and where is it.This my first lt1
Old Aug 9, 2014 | 08:23 AM
  #17
Just about anything you want/need to know is already offered in the links posted in this 7 year old thread. My website is full of info (links above and in sig).
Old Aug 9, 2014 | 08:32 AM
  #18
HardcoreRM125's Avatar
Spend some time on Shoebox's website. It is the most complete single source on the web for labeled pictures, part #'s, DTC's, etc.
I bought my car 11 years ago, totaled, when I was 15-16? And towed it home with no engine or trans in it. Two truck beds full of parts.
Shoebox's website showed me 99% of everything I needed to rebuild the car and get everything hooked up properly when I wasn't the one who took it apart.
It has been in my bookmarks now for 11 years, across 4 computers, 2 failed relationships lol, etc.
Old Aug 9, 2014 | 10:48 AM
  #19
...... Also what is the opti spark and where is it.This my first lt1
The Optispark is the distributor. Unlike all earlier small block Chevy engines, it is not located on top/back of the intake manifold. It is mounted on the front of the timing cover, concentric with the centerline of the camshaft, and is driven either by a splined shaft inserted into the cam sprocket (93/94) or by the cam dowel pin (95-97). In that location, it is susceptible to damage from coolant dripping from the water pump weep hole, or from any water or coolant that is dripped or sprayed on the front of the engine.
The Opti functions like a conventional distributor - cap and rotor route the high voltage from the coil to the correct spark plug. In addition, there is also an optical cam position sensor that provides the PCM (computer) with the data it needs to time the ignition, drive the tach (94-97 only), and time the sequential fuel injection (94-97 only).
Courtesy of Shoebox:
http://shbox.com/ci/opti_mounting.jpg
Old Aug 9, 2014 | 01:42 PM
  #20
That's hilarious.
Old Aug 30, 2014 | 08:35 PM
  #21
ToocoolZ28's Avatar
I replaced the heater hoses on my 95 Z28 with just regular hose, no bleeders a few years ago. It took a couple of days of driving a little then adding a little more fluid but I don't have any problems. I think you are over thinking this.
Old Aug 30, 2014 | 09:07 PM
  #22
You do realize that you still have one bleeder on the t'stat housing? Or did you find some way to eliminate that as well?
I guess GM just wasted a lot of money providing the Corvette version of the LT1 with a complicated "self-bleeding" system.
Old Aug 30, 2014 | 10:31 PM
  #23
ToocoolZ28's Avatar
I wouldn't say that, I just did what I had to do so I could drive the car . I have always meant to buy the correct hoses and do it up right, I just haven't got around to it.
Rod Bender
Nov 7, 2023 02:30 PM
blac94Z
Feb 15, 2021 09:43 PM
warmeck
May 31, 2015 11:29 AM
Biggiebound
Apr 21, 2015 11:28 PM
Sandersen511
Jan 13, 2015 03:49 PM
