bleeding abs unit
Old Mar 31, 2004 | 06:27 PM
djc485's Avatar
Question bleeding abs unit
This isnt for an lt1 but a 1500 97 silverado. I just did a brake job and put new rotors pads drums and shoes on. I adjusted everything correctly ( I checked several times because I thought it was the problem). After I did all this and bled the system the pedal was lower than before. Ithen replaced the brake booster and master cylinder and bled the system once again. This yielded no result. My neighbor told me that he the abs system needed to be bled apparently this is unrelated to the normal way you bleed brakes. My question is was he correct and if so how do I bleed an abs unit?
Old Mar 31, 2004 | 07:08 PM
97RedT/AWS-6's Avatar
Your ABS unit should have bleeder screws on it. Bleed the ABS box, bleed your brakes, then re-bleed the ABS.
Old Mar 31, 2004 | 08:16 PM
djc485's Avatar
Is the abs box located on the caliper, if not where?
Old Mar 31, 2004 | 11:00 PM
The ABS unit should be under the hood. Follow the brake lines from your master cylinder to a metal box. This is the ABS unit. Look for the bleeder screws on the box. Hope this helps...
Old Mar 31, 2004 | 11:17 PM
djc485's Avatar
Awesome thank you!
Formula Steve
Sep 19, 2023 08:31 AM
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
frankrizz
Sep 23, 2015 04:21 PM
1bad427ls1
Sep 23, 2015 01:12 AM
