Bleeder screws
Old Aug 20, 2004 | 11:42 AM
BLDun's Avatar
Bleeder screws
Question: are there more than two bleeder screws for the cooling system on a '94 LT1??? I can only find two and wondered if I'm missing one. I am running a little warm after replacing the elec water pump and don't know if I have all the air out or not.
Old Aug 20, 2004 | 11:54 AM
Re: Bleeder screws
Just the two.
Old Aug 20, 2004 | 11:56 AM
BLDun's Avatar
Re: Bleeder screws
OK thanks!!!
Old Aug 20, 2004 | 12:53 PM
flyinZ's Avatar
Re: Bleeder screws
It'll take a while to get all the air out of there...Just keep checkin' the coolant level, until ya get it full..Maybe check it while the car is runnin, if ya can..(before it gets too hot)
Old Aug 20, 2004 | 01:36 PM
BLDun's Avatar
Re: Bleeder screws
should you be able to get air/water out of both bleeder valves when the car is running and hot? When I open the one closest to the water pump I get coolant quickly but I can open the other all the way and get nothing. Does it only come out there when it is first started up or do I just need to keep waiting and adding fluid until it comes out the same way??
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
Henson071
Aug 4, 2015 09:32 AM
WOT
Sep 1, 2002 11:45 PM
6speedZ28
Jul 25, 2002 12:41 AM
