Autocross and Road Racing Technique There is more to life than a straight line
Teflon tape on brake bleeder screws?
Old Sep 1, 2002 | 05:38 PM
WOT's Avatar
WOT
Question Teflon tape on brake bleeder screws?
I'm swapping my brake fluid to ATE Super Blue and will be using a vaccuum pump. Is it safe to use teflon tape on the bleeder screw threads to get a better seal?
1994 Chevrolet Camaro B4C 5.7L LT1 V8/T56 tranny 1 of 334
2000 Chevrolet Silverado LT Z71
http://wot.50megs.com/B4C.htm
Old Sep 1, 2002 | 11:41 PM
lateapex's Avatar
Post
If you are using the original cast iron front calipers, then it is safe to use 1 layer of Teflon tape. The rear calipers are aluminum; I wouldn't use tape on them or you might crack them. If you are trying to avoid the "micro bubbles" that are sucked past the bleed screw threads, you might get the OEM bleed screw caps. I have found that the plastic retaining collar (that goes below the shoulder of the bleed screw) for the cap almost eliminates the air bubbles if you don't open the screw more than 1/4 turn.
Bob Bishop
lateapex@charter.net
'94 Z28 with C5 front brakes and other road racing stuff
Old Sep 1, 2002 | 11:45 PM
WOT's Avatar
WOT
Post
Yeah I'm trying to avoid the micro-bubbles. Thanks for the tips Bob!
Henson071
Aug 4, 2015 09:32 AM
surreybrad
Jul 29, 2015 02:55 PM
Boss002
Jul 24, 2015 10:47 AM
Jul 10, 2015 02:23 PM
