Black rubber strip that runs along bottom edge of window..
Old Jun 13, 2003 | 11:51 AM
94 CAMRO Z28's Avatar
Angry Black rubber strip that runs along bottom edge of window..
It keeps popping up and almost off everytime I close the door. Has anyone else ever had this problem? Whats the solution? Cut the metal tabs off and RTV it down?
Aaron
Old Jun 13, 2003 | 05:17 PM
z28jaz's Avatar
That sounds more like a problem with window or door alignment than with the strip. If you close the door with the window down, does it still pop off?
Old Jun 13, 2003 | 09:36 PM
Yes that is when it is the worse. When the window is down theres not pressure against it to help hold it. It stays pretty much normal and isn't a problem when the window is up or mostly up. Only when its half down or more.
Aaron
Old Jun 13, 2003 | 10:34 PM
RUFFIDLNZ's Avatar
I have had the same problem as well. Its only held on by little metal clips that get rusty over time and either bend or break. Once they do this it loses its hold on the metal lip that is on the door. You can get a new rubber piece that has the clips on them and intall it. Only thing is its a major PITA not to mention you have to be really careful not to scratch your car while installing it.
Old Jun 14, 2003 | 03:04 PM
BennyBoy's Avatar
My strip has popped up as well. I think someone was trying to break in and popped this strip up. So all we need to buy is the rubber strip? Do we need to remove the window to replace it?
Old Jun 14, 2003 | 03:40 PM
naaz90's Avatar
just replace the strip, it thinks its around $18. you dont have to take the window out but you have to move the mirror support to get the strip under it. Its not to bad to install just take your time with it.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Dec 1, 2014 08:08 AM
RedLineRev
Jan 23, 2003 03:51 PM
