The bird died
Old Oct 5, 2003 | 04:47 PM
Andrew Duke's Avatar
The bird died
Ive searched forums and can't find a problem like mine. My bird was surging and idling high so I replaced my egr valve which cured most of the problem. Then a couple of days ago it shut off when I gave it gas at a stoplight and I took 5 minutes to get it cranked up again. After I got it to a gas station it would not crank up again at all unless I hold the gas at WOT while cranking the car. Then it will only stay running above 2000 RPMS. If I let off the gas at all it will shut off. Ive replaced the O2 sensors and IAC valve and that did not help the problem at all. Any help is appreciated... man i need a different daily driver!
Old Oct 6, 2003 | 01:16 AM
PoorMan's Avatar
My friends 97 Z28 started with this same problem a few days ago. Now it will not start at all. Before this he had to give it full throttle to start it and then keep it above 1000 rpm for it to stay running. We found out today that his fuel pressure regulator was bad. No pressure on the rail. Replaced it with a new one and still no start. He doesn't have EGR btw. It must of gone out by trying to start it so much?? hell, i don't know. Anyway, before we called it a day we found that he had a few bad plug wires. No spark on several cylinders. So, after he buys new wires then we hope it will fix the problem. Going to check the TPS voltage next.
Jeff D.
Old Oct 6, 2003 | 05:00 PM
JONEZ_Z's Avatar
You try the fuel filter?
Old Oct 6, 2003 | 05:31 PM
SAP_Pete's Avatar
I had similar symptoms, and went on a tear and replaced plugs, wires and ignition coil, and blocked off EGR. No problems since.
Old Oct 8, 2003 | 02:35 PM
test
Old Oct 8, 2003 | 02:38 PM
ok i havent been able to post at reply for some reason.. I got the car back from the mechanic and it turned out that my engine coolant temperature sensor was reading -40 deg. and thats why it was flooding so bad. thanks for the help guys. this problem turned out to be a freak one and i hope it might help someone out in the future.
Formula Steve
Sep 19, 2023 08:31 AM
68camaroboltz
Oct 5, 2015 01:46 PM
Bxlt1
Sep 29, 2015 03:18 PM
KYWes
Sep 26, 2015 08:49 AM
