Billet underdrive pully. Look here
Old Feb 15, 2006 | 01:33 PM
MAJESTIC's Avatar
I messed up my pully trying to tap it off with a hammer. I chipped the
edge of it. I was told I knock the balance off it by doing that, and I needed
a new one. I was looking on e-bay and found some real cheap underdrive
pully just for the crank. Does anyone have any info on this type of pully.
Has anyone used this type of pully? I am thinking of a purchase, unless
someone says otherwise.
http://cgi.ebay.com/ebaymotors/BILLE...QQcmdZViewItem
Old Feb 15, 2006 | 01:36 PM
Javier97Z28's Avatar
Moderator
Re: Billet underdrive pully. Look here
LT1 is internally balanced... as long as the pulley works, it works.
That pulley you posted is one of those piggy-back pulleys anyways, still needs the stocker bolted on.
I love how the ebay says the billet pulley equals less weight, when it still uses the factory pulley.
Old Feb 15, 2006 | 04:00 PM
nathan96's Avatar
Wait, why would it still need the stock pulley? It looks like it has everything to bolt up the hub?
Old Feb 15, 2006 | 04:17 PM
But its looks like its only a "pulley". And its priced like its only a "pulley". The stock piece is both a "pulley" and a "harmonic damper". You need the damper to continue to function, so you pull the stock integrated pulley/damper off, sandwich the U/D pulley behind it and put the stock piece back on, to help keep your crankshaft in one piece. As Javier pointed out, you just added weight.
G-BODYT56
Jan 14, 2022 11:14 PM
RUENUF
Mar 13, 2016 03:37 PM
n2oblkz
Oct 22, 2015 02:31 PM
95chwagon
Oct 16, 2015 12:24 PM
Slayer
Aug 17, 2015 03:55 PM
