Biggest Stoker
Old Dec 31, 2003 | 01:11 AM
TaylnStorm's Avatar
Biggest Stoker
What is the biggest possible displacement an LT1 can become? I heard somewhere around 407ci. True?
Old Dec 31, 2003 | 01:41 AM
carlos64030's Avatar
I think 422 is the largest. I've seen a few LT1's stroked to a 406.
Old Dec 31, 2003 | 02:42 AM
Spinner's Avatar
I've seen 431... but it was a welded/relieved/sleeved block
Old Dec 31, 2003 | 11:35 AM
94droptopz's Avatar
you can buy the kit for a daily driver 427.
Old Dec 31, 2003 | 11:54 AM
422.... 431.... 427.... Can you give me a link to any of these?
Largest LT1's I have seen are the two 421's built by Mark Montalvo....
4.030 X 4.125 stroke = 420.93ci
4.090 X 4.000 stroke = 420.42ci
Better have a big limit on the ol' credit card.
Old Dec 31, 2003 | 12:26 PM
chad_g69's Avatar
i got 427 and use it as a daily driver
block is sleeved, filled, releaved, x-rayed
4.12 bore, 4.0 stroke
11.5:1 compression
small cam - to pass CA smog
-chad
Old Dec 31, 2003 | 12:59 PM
Cmr0z28's Avatar
Fred -- I had a magazine, and there was a Lingenfelter-built LT1 vette with 427ci.
Old Dec 31, 2003 | 01:39 PM
94droptopz's Avatar
http://www.moreperformanceinc.com/cranks.htm
heres one for the ls1.
Old Dec 31, 2003 | 02:15 PM
got_hp?'s Avatar
11.5:1 compression
-chad
damn..........how long have you been driving it? ive heard problems with sleeved blocks
how much did the machine work cost, and what crank are you using?
Old Dec 31, 2003 | 02:52 PM
dnz28's Avatar
I believe a aftermarket block just came out for the lt1 forgot th company that makes it but they were talking about a 454 lt1 capability.
Old Dec 31, 2003 | 03:26 PM
LameRandomName's Avatar
What?!?! You heard about this and failed to take notes? Get a phone number? A mailing address? Anything?
Arrrrggggghhhhh!!!!
Old Dec 31, 2003 | 05:38 PM
got_hp?'s Avatar
Arrrrggggghhhhh!!!!
it was posted on the board........i think it was just a rumor, like someone heard from someone who heard from someone......world products might make one.
Old Dec 31, 2003 | 06:07 PM
brain's Avatar
Chad, curious, why go to such trouble with the block for the displacement, and then put in a hotcam? I would figure it to have easily over 475 rwhp with a larger cam. I bet it drives like a stock camaro tho. Do you have any dyno sheets you can post?
Old Dec 31, 2003 | 06:08 PM
dnz28's Avatar
no its not a "rumor" there is a block out and I got this info from a magazine that was testing it. I think someone posted about it but its all true. I will do a little research and get back to you guys.
Old Dec 31, 2003 | 06:45 PM
chad_g69's Avatar
my dyno specs from my most recent dyno tune is in my signature
no recent track times... any tracks in the santee area??
can post dyno sheet after my home computer is replaced (were my scanner is at, im using computer @ work now)
needed small cam due to CA smog checks, got pulled over last week, and they inspected it
-chad
PS: i can get more then 475 RWHP with a bigger cam
my friend has a 355 w/ 10:1 compression with a BIG cam (cc306 i think) and head work/LT1 Edit, and basic mods: 420RWHP 380Ft. Lbs. Tq.
