Biggest cam for daily driver??????????
Old Jan 13, 2006 | 09:49 AM
  #16
fireman's Avatar
Re: Biggest cam for daily driver??????????
I run a CC306 with unported heads, mine runs pretty good.
Old Jan 13, 2006 | 10:40 AM
  #17
truedualws6's Avatar
I was going to avoid responding to this post because opinions of a
daily driver cam are so varied it's impossible to have a discussion. To
clarify a bit more, for me a daily driver is a car that is driven daily in
rush hour traffic, in California, and also must pass smog.
With that, the CC503 and GM 846 are the absolute most you can go.
You may still have some drivability issues, but with the right tuning
and everything else working, you should pass smog. I'm daily driving
a baby Crane 227 and there is no way someone is going to tell me that
a CC306 is a daily driver. I had a RAIV cam in my 68 GTO, which has
very similar specs to the 306, plus a 3000 stall converter and 3:73s
and there is no way I would have considered it a daily driver.
Old Jan 13, 2006 | 11:27 AM
  #18
96flame's Avatar
Gotta remember fuel injection makes a bigger cam more liveable than a carbed motor
Old Jan 13, 2006 | 11:42 AM
  #19
96flame's Avatar
Originally Posted by Heatmaker
What are your actual installed mods on your car???
I'm pretty sure he doesn't have the cam installed because he asked yesterday what springs and rockers to buy. Two days ago he asked how much power a certain setup would make. Do a search on threads started by this guy and have a good laugh. If you're like me you'll quit responding to him.
Old Jan 13, 2006 | 01:20 PM
  #20
Z06Z28's Avatar
Originally Posted by scyzoryk
I love my XE 224/230. With all supporting mods I managed to get very close to 400RWHP...
Sebastian
I'm looking at the same Cam, What Mods do you have so I can get an idea. Also, shoot me your car info...year, tranny info...yada yada... Thanks.
Old Jan 13, 2006 | 01:48 PM
  #21
sbs's Avatar
sbs
Dang. You ain't kidding. He's been asking the same confused questions for a year now.
Going back through them I recognize a lot of those threads, but never realized they were all the same person.
BadCamaro, you've been here at least a year. Have you read any of the threads on heads, cams, engine building, anything in that time?
Old Jan 13, 2006 | 02:51 PM
  #22
scyzoryk's Avatar
1995 Pontiac Trans AM M6 60k miles, T-Tops, Leather
396RWHP 377RWTQ
Mods: (all mods have about 10k miles)
GTP Stage II Heads
Ported Intake
Comp Cams XE 224/230 Cam
Crane Gold Race 1.6 ratio rockers
Trickflow chromemoly pushrods
AS&M 54mm throttle body
K&N FIPK CAI
FMS 42lb/hr injectors
MSD BTM Ignition
MAC MID headers
ORP + cut-out -no cat
SLP Exhaust with electric cutout
Pro 5.0 Shifter
SPEC Stage 4 Clutch kit
Rebuild 4.10 rear with Auburn Posi
TA Cover + Custom Welded Axle tubes
LS1 aluminium driveshaft
Harwood Ram Air Hood
‘98+ Tail lights
35mm ST sway bar
LG Subframe Connectors
Double Adjustable PHP
BMR LCA
3 point STB
Ground Control coilovers spring rate:500frt:150bck with bilstein shocks: revalved fronts: stock back
Front: TTII 17x9.5 275/40/17 BFG KDW
Rear:TTII 17x11 315/35/17 Nitto DR
+ 2 hours of dyno tunning +new oxyngen sensors, plugs, cables, fuell filter (all tunaup parts)
Sebastian
ps. My car is for sale $9k
Old Jan 13, 2006 | 04:18 PM
  #23
crAzy95z28's Avatar
i think i have a farely HUGE cam in my car!!
the car will be ready next week with a forged 355 with a 236/242 cam 565/579 lift on 112lsa!
Havent driven it yet, but it will be with a 3200 stall and a built tranny.
Last engine i had 210/224 cam and it drove great for street! I will just have to wait and see. I will be sure to post and let you know!
Randy
Old Jan 13, 2006 | 04:48 PM
  #24
Heatmaker's Avatar
Advanced Member
I think he might have his mods... I just don't think he is the one installign them, and that's why he's unfamiliar with his car, and the parts.
Old Jan 13, 2006 | 05:06 PM
  #25
blown383's Avatar
I had a 236/242 @ .050; .579/.576 lift on a 110lsa, with long tubes, 3.42s in the rear, MadZ28 tune, stock heads, and M6. It ran fine.... I actually wished I went with a bigger cam.
-B
Old Jan 13, 2006 | 08:04 PM
  #26
my94blackz's Avatar
Originally Posted by Bersaglieri
my94blackZ - Do you have bolt ons or just the cam and heads? I assume since you listed the heads in your sig that they are ported and polished? I just wondered cause if you have full bolt on's and P&P Heads you should be seeing nearly 400rwhp with that cam. I am pretty sure Madwolf was in the 350's rwhp with stock heads and bolt on's with his XE 233/239.
-Dustin-
My Sig is very old, I had some faulty valve springs when i dynoed (not strong enough), and also my heads are home ported not much better than stock. With the new valve springs and the new duals im prolly well over 400. I have run some 400+ cars and stayed with them outrunning some. Note these were ls1 cars, which are much lighter. I am at full weight plus some added weight most of them are on 15's with reduction yet im still winning. So i figure im out to about 400-415 now.
Old Jan 13, 2006 | 09:00 PM
  #27
Bersaglieri's Avatar
Alright, that makes more sense. Update the sig man!
-Dustin-
Old Jan 13, 2006 | 10:17 PM
  #28
96ta(nick)'s Avatar
Randy
Ha! try mine on for size. 245/254 .595/.604 112lsa In a 355..
Old Jan 13, 2006 | 10:59 PM
  #29
ABA383's Avatar
FWIW, I remember this guy from a while ago and I think that English is a second language for him and he is learning both English and modding....I guess we should take it easy on him...Leave the 306 and save for porting the heads...
--Alan
Old Jan 14, 2006 | 08:43 PM
  #30
357LT1's Avatar
That is a custom cam right? I want to replace my CC306 in my 357, I want something in the 24x/24x range too. How does your car drive with that big thing? Any power #'s? Thanks!
Ramiro
